Change ISL properties and IOD/OOD configuration on a Cisco FC switch in a MetroCluster FC configuration
You can add Inter-Switch Links (ISLs), change ISL speed, and reconfigure in-order delivery (IOD) or out of-order delivery (OOD) settings on a Cisco FC switch.
Add ISLs to a Cisco FC switch
You might need add ISLs to a switch if you are adding or upgrading hardware, for example, adding or upgrading to faster controllers or faster switches.
Perform these steps on both switches in the fabric to verify ISL connectivity.
Disable the ISL ports of the ISLs to be added on both switches in the fabric:
FC_switch_A_1#config tEnter the following configuration commands, one per line. Enter CTRL-Z after you have entered all of the configuration commands.
FC_switch_A_1(config)# interface fc1/36 FC_switch_A_1(config-if)# shut FC_switch_A_1(config)# end
Insert SFPs into the ports you are adding as ISL ports, and cable them according to Cable a fabric-attached MetroCluster configuration.
Verify that these ports are listed in the cabling documentation for the switch model that you are adding them to.
Configure the ISL ports by following the steps in Cabling the ISLs between MetroCluster sites.
Enable all ISL ports (if not enabled) on both switches in the fabric:
FC_switch_A_1# config tEnter the following configuration commands, one per line. End with CTRL-Z after you have entered all of the configuration commands.
FC_switch_A_1# interface fc1/36 FC_switch_A_1(config-if)# no shut FC_switch_A_1(config)# end
Verify that the ISLs are established between both switches:
show topology isl -
Repeat the procedure on the second fabric:
-------------------------------------------------------------------------------- __________Local_________ _________Remote_________ VSAN Cost I/F PC I/F Band PC Domain SwName Port Port SwName Domain PC Stat Stat Speed width -------------------------------------------------------------------------------- 1 0x11 cisco9 fc1/36 fc1/36 cisco9 0xbc 1 1 15 up up 16g 64g 1 0x11 cisco9 fc1/40 fc1/40 cisco9 0xbc 1 1 15 up up 16g 64g 1 0x11 cisco9 fc1/44 fc1/44 cisco9 0xbc 1 1 15 up up 16g 64g 1 0x11 cisco9 fc1/48 fc1/48 cisco9 0xbc 1 1 15 up up 16g 64g
Change ISL port speeds on a Cisco FC switch
You can change the speed of ISL ports on a switch to improve the quality of the ISL, for example, lowering the speed on ISLs traveling a greater distance.
Disable the ISL ports for the ISLs that you want to change the speed for on both switches in the fabric:
Change the speed of the ISL ports on both switches in the fabric:
FC_switch_A_1(config)# interface fc1/36 FC_switch_A_1(config-if)# switchport speed 16000
Speeds for the ports are 16 = 16,000 Gbps, 8 = 8,000 Gbps, and 4 = 4,000 Gbps. Verify that the ISL ports for your switch are listed in Install a fabric-attached MetroCluster configuration.
FC_switch_A_1(config)# interface fc1/36 FC_switch_A_1(config-if)# no shut FC_switch_A_1(config)# end
show topology isl-------------------------------------------------------------------------------- __________Local_________ _________Remote_________ VSAN Cost I/F PC I/F Band PC Domain SwName Port Port SwName Domain PC Stat Stat Speed width -------------------------------------------------------------------------------- 1 0x11 cisco9 fc1/36 fc1/36 cisco9 0xbc 1 1 15 up up 16g 64g 1 0x11 cisco9 fc1/40 fc1/40 cisco9 0xbc 1 1 15 up up 16g 64g 1 0x11 cisco9 fc1/44 fc1/44 cisco9 0xbc 1 1 15 up up 16g 64g 1 0x11 cisco9 fc1/48 fc1/48 cisco9 0xbc 1 1 15 up up 16g 64g
Repeat the procedure for the second switch fabric.
Reconfigure the VSAN to guarantee IOD or OOD of frames
The standard IOD settings are recommended. You should only reconfigure OOD if necessary.
Reconfigure IOD
Perform the following step to reconfigure IOD of frames.
Enter configuration mode:
conf t -
Enable the in-order guarantee of exchanges for the VSAN:
in-order-guarantee vsan <vsan-ID>For FC-VI VSANs (FCVI_1_10 and FCVI_2_30), you must enable in-order guarantee of frames and exchanges only on VSAN 10. -
Enable load balancing for the VSAN:
vsan <vsan-ID> loadbalancing src-dst-id -
Exit configuration mode:
end -
Copy the running-config to the startup-config:
copy running-config startup-configThe commands to configure IOD of frames on FC_switch_A_1:
FC_switch_A_1# config t FC_switch_A_1(config)# in-order-guarantee vsan 10 FC_switch_A_1(config)# vsan database FC_switch_A_1(config-vsan-db)# vsan 10 loadbalancing src-dst-id FC_switch_A_1(config-vsan-db)# end FC_switch_A_1# copy running-config startup-config
The commands to configure IOD of frames on FC_switch_B_1:
FC_switch_B_1# config t FC_switch_B_1(config)# in-order-guarantee vsan 10 FC_switch_B_1(config)# vsan database FC_switch_B_1(config-vsan-db)# vsan 10 loadbalancing src-dst-id FC_switch_B_1(config-vsan-db)# end FC_switch_B_1# copy running-config startup-config
Reconfigure OOD
Perform the following steps to reconfigure OOD of frames.
conf t -
Disable the in-order guarantee of exchanges for the VSAN:
no in-order-guarantee vsan <vsan-ID> -
end -
copy running-config startup-configThe commands to configure OOD of frames on FC_switch_A_1:
FC_switch_A_1# config t FC_switch_A_1(config)# no in-order-guarantee vsan 10 FC_switch_A_1(config)# vsan database FC_switch_A_1(config-vsan-db)# vsan 10 loadbalancing src-dst-id FC_switch_A_1(config-vsan-db)# end FC_switch_A_1# copy running-config startup-config
The commands to configure OOD of frames on FC_switch_B_1:
FC_switch_B_1# config t FC_switch_B_1(config)# no in-order-guarantee vsan 10 FC_switch_B_1(config)# vsan database FC_switch_B_1(config-vsan-db)# vsan 10 loadbalancing src-dst-id FC_switch_B_1(config-vsan-db)# end FC_switch_B_1# copy running-config startup-config
When configuring ONTAP on the controller modules, OOD must be explicitly configured on each controller module in the MetroCluster configuration.
