ONTAP MetroCluster
Power off an entire MetroCluster IP configuration
Contributors netapp-aoife netapp-thomi netapp-ivanad
Power off the entire MetroCluster IP configuration and all of the equipment before starting maintenance or relocation.
Note Beginning with ONTAP 9.8, the storage switch command is replaced with system switch. The following steps show the storage switch command, but if you are running ONTAP 9.8 or later, the system switch command is preferred.
  1. Verify the MetroCluster configuration from both sites.
    1. Confirm that the MetroCluster configuration and operational mode are normal.
      metrocluster show
    2. Run the following command:
      metrocluster interconnect show
    3. Confirm connectivity to the disks by entering the following command on any one of the MetroCluster nodes:
      run local sysconfig -v
    4. Run the following command:
      storage port show
    5. Run the following command:
      storage switch show
    6. Run the following command:
      network interface show
    7. Run the following command:
      network port show
    8. Run the following command:
      network device-discovery show
    9. Perform a MetroCluster check:
      metrocluster check run
    10. Display the results of the MetroCluster check:
      metrocluster check show
    11. Run the following command:
      metrocluster configuration-settings interface show
  2. If necessary, disable AUSO by modifying the AUSO Failure Domain to
    auso-disabled
    cluster_A_site_A::*>metrocluster modify -auto-switchover-failure-domain auso-disabled
    Note In a MetroCluster IP configuration, the AUSO Failure Domain is already set to 'auso-disabled' unless the configuration uses ONTAP Mediator.
  3. Verify the change using the command
    metrocluster operation show
    	cluster_A_site_A::*> metrocluster operation show
           Operation: modify
               State: successful
          Start Time: 4/25/2020 20:20:36
            End Time: 4/25/2020 20:20:36
              Errors: -
  4. Halt the nodes at both sites:
    cluster_A::*>system node halt -node * -inhibit-takeover true -ignore-quorum-warnings true
    cluster_B::*>system node halt -node * -inhibit-takeover true -ignore-quorum-warnings true
  5. Power off the following equipment at the site:
    • Storage controllers
    • MetroCluster IP switches
    • Storage shelves
  6. Wait for thirty minutes and then power on all storage shelves, MetroCluster IP switches, and storage controllers.
  7. After the controllers are powered on, verify the MetroCluster configuration from both sites.
    To verify the configuration, repeat step 1.
  8. Perform power cycle checks.
    1. Verify that all sync-source SVMs are online:
      vserver show
    2. Start any sync-source SVMs that are not online:
      vserver start
