ONTAP MetroCluster
Power off an entire MetroCluster FC configuration
Contributors netapp-aoife netapp-folivia netapp-thomi netapp-ivanad
You must power off the entire MetroCluster FC configuration and all of the equipment before site maintenance or relocation can begin.
About this task
You must perform the steps in this procedure from both sites, at the same time.
Note Beginning with ONTAP 9.8, the storage switch command is replaced with system switch. The following steps show the storage switch command, but if you are running ONTAP 9.8 or later, the system switch command is preferred.
Steps
  1. Verify the MetroCluster configuration from both sites in the MetroCluster configuration.
    1. Confirm the MetroCluster configuration and that the operational mode is normal.
      metrocluster show
    2. Confirm connectivity to the disks by entering the following command on any one of the MetroCluster nodes:
      run local sysconfig -v
    3. Run the following command:
      storage bridge show
    4. Run the following command:
      storage port show
    5. Run the following command:
      storage switch show
    6. Run the following command:
      network port show
    7. Perform a MetroCluster check:
      metrocluster check run
    8. Display the results of the MetroCluster check:
      metrocluster check show
  2. Disable AUSO by modifying the AUSO Failure Domain to
    auso-disabled
    cluster_A_site_A::*>metrocluster modify -auto-switchover-failure-domain auso-disabled
  3. Verify the change using the command
    metrocluster operation show
    	cluster_A_site_A::*> metrocluster operation show
           Operation: modify
               State: successful
          Start Time: 4/25/2020 20:20:36
            End Time: 4/25/2020 20:20:36
              Errors: -
  4. Halt the nodes by using the following command: halt
    • For a four-node or eight-node MetroCluster configuration, use the inhibit-takeover and skip-lif-migration-before-shutdown parameters:
      system node halt -node node1_SiteA -inhibit-takeover true -ignore-quorum-warnings true -skip-lif-migration-before-shutdown true
    • For a two-node MetroCluster configuration, use the command:
      system node halt -node node1_SiteA -ignore-quorum-warnings true
  5. Power off the following equipment at the site:
    • Storage controllers
    • MetroCluster FC switches (if in use and the configuration is not a a two-node stretch configuration)
    • ATTO FibreBridges
    • Storage shelves
  6. Wait for thirty minutes and then power on the following equipment at the site:
    • Storage shelves
    • ATTO FibreBridges
  7. After the controllers are powered on, verify the MetroCluster configuration from both sites.
    To verify the configuration, repeat step 1.
  8. Perform power cycle checks.
    1. Verify that all sync-source SVMs are online:
      vserver show
    2. Start any sync-source SVMs that are not online:
      vserver start
