Cable the management and data connections for a stretch MetroCluster configuration
You must cable the management and data ports on each storage controller to the site networks.
This task must be repeated for each new controller at both MetroCluster sites.
You can connect the controller and cluster switch management ports to existing switches in your network. In addition you can connect controller to new dedicated network switches such as NetApp CN1601 cluster management switches.
Steps
Cable the controller's management and data ports to the management and data networks at the local site.
