ONTAP MetroCluster
Example naming for a MetroCluster FC-to-IP transition
Contributors netapp-thomi NetAppZacharyWambold netapp-aherbin
This procedure uses example names throughout to identify the DR groups, nodes, and switches involved.
DR groups
cluster_A at site_A
cluster_B at site_B
dr_group_1-FC
  • node_A_1-FC
  • node_A_2-FC
  • node_B_1-FC
  • node_B_2-FC
dr_group_2-IP
  • node_A_3-IP
  • node_A_4-IP
  • node_B_3-IP
  • node_B_4-IP
Switches
Initial switches (if fabric-attached configuration:)
  • switch_A_1-FC
  • switch_A_2-FC
MetroCluster IP switches:
  • switch_A_1-IP
  • switch_A_2-IP
Initial switches (if fabric-attached configuration):
  • switch_B_1-FC
  • switch_B_2-FC
  • switch_B_1-IP
  • switch_B_2-IP
