Upgrade controllers in a four-node MetroCluster FC configuration using switchover and switchback with "system controller replace" commands (ONTAP 9.10.1 and later)
You can use this guided automated MetroCluster switchover operation to perform a non-disruptive controller upgrade on a four-node MetroCluster FC configuration. Other components (such as storage shelves or switches) cannot be upgraded as part of this procedure.
Supported platform combinations
For information on what platform upgrade combinations are supported, review the MetroCluster FC upgrade table in Choose a controller upgrade procedure.
Refer to Choose an upgrade or refresh method for additional procedures.
About this task
You can use this procedure only for controller upgrade.
Other components in the configuration, such as storage shelves or switches, cannot be upgraded at the same time.
This procedure applies to controller modules in a four-node MetroCluster FC configuration.
The platforms must be running ONTAP 9.10.1 or later.
You can use this procedure to upgrade controllers in a four-node MetroCluster FC configuration using NSO based automated switchover and switchback. If you want to perform a controller upgrade using aggregate relocation (ARL), refer to Use "system controller replace" commands to upgrade controller hardware running ONTAP 9.8 or later. It is recommended to use the NSO based automated procedure.
If your MetroCluster sites are physically at two different locations, you should use the automated NSO controller upgrade procedure to upgrade the controllers at both sites in sequence.
This automated NSO based controller upgrade procedure gives you the capability to initiate controller replacement to a MetroCluster disaster recovery (DR) site. You can only initiate a controller replacement at one site at a time.
To initiate a controller replacement at site A, you need to run the controller replacement start command from site B. The operation guides you to replace controllers of both the nodes at site A only. To replace the controllers at site B, you need to run the controller replacement start command from site A. A message displays identifying the site at which the controllers are being replaced.
The following example names are used in this procedure:
site_A
Before upgrade:
node_A_1-old
node_A_2-old
After upgrade:
node_A_1-new
node_A_2-new
site_B
Before upgrade:
node_B_1-old
node_B_2-old
After upgrade:
node_B_1-new
node_B_2-new
Enable console logging
NetApp strongly recommends that you enable console logging on the devices that you are using and take the following actions when performing this procedure:
Leave AutoSupport enabled during maintenance.
Trigger a maintenance AutoSupport message before and after maintenance to disable case creation for the duration of the maintenance activity.
See the Knowledge Base article How to suppress automatic case creation during scheduled maintenance windows.
Enable session logging for any CLI session. For instructions on how to enable session logging, review the "Logging Session Output" section in the Knowledge Base article How to configure PuTTY for optimal connectivity to ONTAP systems.
Prepare for the upgrade
To prepare for the controller upgrade, you need to perform system prechecks and collect the configuration information.
At any stage during the upgrade, you can run the system controller replace show or system controller replace show-details command from site A to check the status. If the commands return a blank output, wait for a few minutes and rerun the command.
Run the following command from site A to replace the controllers at site B:
system controller replace start-
If you're repeating the procedure at one site, after already replacing the controllers at the other site, an error occurs due to a mismatch between the nodes at each site. This is the expected behavior when there are different platform models on both sites.
If only the mismatch error is returned, you can use the
-skip-metrocluster-check trueoption with thesystem controller replace startcommand to skip the MetroCluster checks.
The automated operation executes the checks. If no issues are found, the operation pauses so you can manually collect the configuration related information.
The current source system and all compatible target systems are displayed. If you have replaced the source controller with a controller that has a different ONTAP version or a non-compatible platform, the automation operation halts and reports an error after the new nodes boot. To bring the cluster back to a healthy state, follow the manual recovery procedure.
The
system controller replace startcommand might report the following precheck error:Cluster-A::*>system controller replace show Node Status Error-Action ----------- -------------- ------------------------------------ Node-A-1 Failed MetroCluster check failed. Reason : MCC check showed errors in component aggregates
Check if this error occurred because you have unmirrored aggregates or due to another aggregate issue. Verify that all mirrored aggregates are healthy and not degraded or mirror-degraded. If this error is due to unmirrored aggregates only, you can override this error by selecting the
-skip-metrocluster-check trueoption on thesystem controller replace startcommand. If remote storage is accessible, the unmirrored aggregates come online after switchover. If the remote storage link fails, the unmirrored aggregates fail to come online. -
Manually collect the configuration information by logging in at site B and following the commands listed in the console message under the
system controller replace showorsystem controller replace show-detailscommand.
Gather information before the upgrade
Before upgrading, if the root volume is encrypted, you must gather the backup key and other information to boot the new controllers with the old encrypted root volumes.
This task is performed on the existing MetroCluster FC configuration.
Label the cables for the existing controllers, so you can easily identify the cables when setting up the new controllers.
Display the commands to capture the backup key and other information:
system controller replace showRun the commands listed under the
showcommand from the partner cluster. -
Gather the system IDs of the nodes in the MetroCluster configuration:
metrocluster node show -fields node-systemid,dr-partner-systemidDuring the upgrade procedure, you will replace these old system IDs with the system IDs of the new controller modules.
In this example for a four-node MetroCluster FC configuration, the following old system IDs are retrieved:
node_A_1-old: 4068741258
node_A_2-old: 4068741260
node_B_1-old: 4068741254
node_B_2-old: 4068741256
metrocluster-siteA::> metrocluster node show -fields node-systemid,ha-partner-systemid,dr-partner-systemid,dr-auxiliary-systemid dr-group-id cluster node node-systemid ha-partner-systemid dr-partner-systemid dr-auxiliary-systemid ----------- --------------- ---------- ------------- ------------------- ------------------- --------------------- 1 Cluster_A Node_A_1-old 4068741258 4068741260 4068741256 4068741256 1 Cluster_A Node_A_2-old 4068741260 4068741258 4068741254 4068741254 1 Cluster_B Node_B_1-old 4068741254 4068741256 4068741258 4068741260 1 Cluster_B Node_B_2-old 4068741256 4068741254 4068741260 4068741258 4 entries were displayed.
In this example for a two-node MetroCluster FC configuration, the following old system IDs are retrieved:
node_A_1: 4068741258
node_B_1: 4068741254
metrocluster node show -fields node-systemid,dr-partner-systemid dr-group-id cluster node node-systemid dr-partner-systemid ----------- ---------- -------- ------------- ------------ 1 Cluster_A Node_A_1-old 4068741258 4068741254 1 Cluster_B node_B_1-old - - 2 entries were displayed.
Gather port and LIF information for each old node.
You should gather the output of the following commands for each node:
network interface show -role cluster,node-mgmt -
network port show -node node-name -type physical -
network port vlan show -node node-name -
network port ifgrp show -node node_name -instance -
network port broadcast-domain show -
network port reachability show -detail -
network ipspace show -
volume show -
storage aggregate show -
system node run -node node-name sysconfig -a
If the MetroCluster nodes are in a SAN configuration, collect the relevant information.
You should gather the output of the following commands:
fcp adapter show -instance -
fcp interface show -instance -
iscsi interface show -
ucadmin show
If the MetroCluster nodes are configured with an external key manager for the admin SVM (cluster), copy the key server information to a secure location. If the Onboard Key Manager is configured, copy the backup information and passphrase to a secure location.
Onboard Key Manager-
Run the following command to display the Onboard Key Manager backup:
security key-manager onboard show-backupYou'll also need the most up-to-date Onboard Key Manager passphrase later in the upgrade procedure.
For additional information, see Back up onboard key management information manually.
External key managerGather the external key management information that you'll need to restore the key manager configuration later in the procedure.
Display the name of the admin SVM (cluster).
vserver show -type adminIn this example, the admin SVM name is cluster_B:
cluster_B::*> vserver show -type admin Admin Operational Root Vserver Type Subtype State State Volume Aggregate ----------- ------- ---------- ---------- ----------- ---------- ---------- cluster_B admin - - - - - -
Obtain the address and port number of a primary key server associated with the external key manager configured on the admin SVM (cluster):
The admin SVM can have up to four primary key servers but you'll only need the port number and address of one of the primary key servers to restore the key management configuration later in the procedure.
If there is a username and password associated with the primary key server you choose, you'll also need that information for the recovery process.
security key-manager external show -instance -vserver <admin_svm_name>cluster_B::> security key-manager external show -instance -vserver cluster_B Vserver: cluster_B Client Certificate: NTAPKM_C Server CA Certificates: NTAPKM_I, NTAPKM_R Primary Key Server: 172.18.27.34:12014 Timeout: 25 Username: Policy name: - Secondary Key Servers: - Create/Remove Timeout: 10 -
If you are running ONTAP 9.16.1 or later, obtain the keystore UUID for the admin SVM.
security key-manager show-key-store -vserver <admin_svm_name> -fields uuidcluster_B::*> security key-manager show-key-store -vserver cluster_B -fields uuid vserver uuid --------------- ------------------------------------ cluster_B f281aa55-d635-11f0-93bc-005056bb68f2 cluster_B::*
Save the information you gathered in a secure location for use later in the procedure. You should now have gathered the following information:
The port number and address of one of the primary key servers for the admin SVM
The user name and password if one is associated with the chosen primary key server
The keystore UUID for the admin SVM (required in ONTAP 9.16.1 or later)
After you finish collecting the configuration information, resume the operation:
system controller replace resume
Remove the existing configuration from the Tiebreaker or other monitoring software
If the existing configuration is monitored with the MetroCluster Tiebreaker configuration or other third-party applications (for example, ClusterLion) that can initiate a switchover, you must remove the MetroCluster configuration from the Tiebreaker or other software prior to replacing the old controller.
Remove the existing MetroCluster configuration from the Tiebreaker software.
Remove the existing MetroCluster configuration from any third-party application that can initiate switchover.
Refer to the documentation for the application.
Replace the old controllers and boot up the new controllers
After you gather information and resume the operation, the automation proceeds with the switchover operation.
The automation operation initiates the switchover, heal-aggregates, and heal root-aggregates operations. After these operations complete, the operation pauses at paused for user intervention so you can rack and install the controllers, boot up the partner controllers, and reassign the root aggregate disks to the new controller module from flash backup using the sysids gathered earlier.
Before initiating switchover, the automation operation pauses so you can manually verify that all LIFs are “up” at site B. If necessary, bring any LIFs that are “down” to “up” and resume the automation operation by using the system controller replace resume command.
Prepare the network configuration of the old controllers
To ensure that the networking resumes cleanly on the new controllers, you must move LIFs to a common port and then remove the networking configuration of the old controllers.
This task must be performed on each of the old nodes.
You will use the information gathered in Prepare for the upgrade.
Boot the old nodes and then log in to the nodes:
boot_ontap -
Assign the home port of all data LIFs on the old controller to a common port that is the same on both the old and new controller modules.
Display the LIFs:
network interface showAll data LIFS including SAN and NAS will be admin “up” and operationally “down” since those are up at switchover site (cluster_A).
Review the output to find a common physical network port that is the same on both the old and new controllers that is not used as a cluster port.
For example, “e0d” is a physical port on old controllers and is also present on new controllers. “e0d” is not used as a cluster port or otherwise on the new controllers.
For port usage for platform models, see the NetApp Hardware Universe
Modify all data LIFS to use the common port as the home port:
network interface modify -vserver svm-name -lif data-lif -home-port port-idIn the following example, this is “e0d”.
For example:
network interface modify -vserver vs0 -lif datalif1 -home-port e0d
Modify broadcast domains to remove VLAN and physical ports that need to be deleted:
broadcast-domain remove-ports -broadcast-domain broadcast-domain-name -ports node-name:port-idRepeat this step for all VLAN and physical ports.
Remove any VLAN ports using cluster ports as member ports and interface groups using cluster ports as member ports.
Delete VLAN ports:
network port vlan delete -node node-name -vlan-name portid-vlandidFor example:
network port vlan delete -node node1 -vlan-name e1c-80
Remove physical ports from the interface groups:
network port ifgrp remove-port -node node-name -ifgrp interface-group-name -port portidFor example:
network port ifgrp remove-port -node node1 -ifgrp a1a -port e0d
Remove VLAN and interface group ports from broadcast domain:
network port broadcast-domain remove-ports -ipspace ipspace -broadcast-domain broadcast-domain-name -ports nodename:portname,nodename:portname,.. -
Modify interface group ports to use other physical ports as member as needed.:
ifgrp add-port -node node-name -ifgrp interface-group-name -port port-id
Halt the nodes:
halt -inhibit-takeover true -node node-nameThis step must be performed on both nodes.
Set up the new controllers
You must rack and cable the new controllers.
Plan out the positioning of the new controller modules and storage shelves as needed.
The rack space depends on the platform model of the controller modules, the switch types, and the number of storage shelves in your configuration.
Properly ground yourself.
Install the controller modules in the rack or cabinet.
If the new controller modules did not come with FC-VI cards of their own and if FC-VI cards from old controllers are compatible on new controllers, swap FC-VI cards and install those in correct slots.
See the NetApp Hardware Universe for slot info for FC-VI cards.
Cable the controllers' power, serial console and management connections as described in the MetroCluster Installation and Configuration Guides.
Do not connect any other cables that were disconnected from old controllers at this time.
Power up the new nodes and press Ctrl-C when prompted to display the LOADER prompt.
Netboot the new controllers
After you install the new nodes, you need to netboot to ensure the new nodes are running the same version of ONTAP as the original nodes. The term netboot means you are booting from an ONTAP image stored on a remote server. When preparing for netboot, you must put a copy of the ONTAP 9 boot image onto a web server that the system can access.
This task is performed on each of the new controller modules.
Access the NetApp Support Site to download the files used for performing the netboot of the system.
Download the appropriate ONTAP software from the software download section of the NetApp Support Site and store the ontap-version_image.tgz file on a web-accessible directory.
Go to the web-accessible directory and verify that the files you need are available.
If the platform model is…
Then…
FAS/AFF8000 series systems
Extract the contents of the ontap-version_image.tgzfile to the target directory: tar -zxvf ontap-version_image.tgz
NOTE: If you are extracting the contents on Windows, use 7-Zip or WinRAR to extract the netboot image.
Your directory listing should contain a netboot folder with a kernel file:netboot/kernel
All other systems
Your directory listing should contain a netboot folder with a kernel file: ontap-version_image.tgz
You do not need to extract the ontap-version_image.tgz file.
At the LOADER prompt, configure the netboot connection for a management LIF:
If IP addressing is DHCP, configure the automatic connection:
ifconfig e0M -auto -
If IP addressing is static, configure the manual connection:
ifconfig e0M -addr=ip_addr -mask=netmask-gw=gateway
Perform the netboot.
If the platform is an 80xx series system, use this command:
netboot http://web_server_ip/path_to_web-accessible_directory/netboot/kernel -
If the platform is any other system, use the following command:
netboot http://web_server_ip/path_to_web-accessible_directory/ontap-version_image.tgz
From the boot menu, select option (7) Install new software first to download and install the new software image to the boot device.
Disregard the following message: "This procedure is not supported for Non-Disruptive Upgrade on an HA pair". It applies to nondisruptive upgrades of software, not to upgrades of controllers.
If you are prompted to continue the procedure, enter
y, and when prompted for the package, enter the URL of the image file:http://web_server_ip/path_to_web-accessible_directory/ontap-version_image.tgzEnter username/password if applicable, or press Enter to continue.
Enter
nto skip the backup recovery when you see a prompt similar to the following:Do you want to restore the backup configuration now? {y|n} n -
Reboot by entering
ywhen you see a prompt similar to the following:The node must be rebooted to start using the newly installed software. Do you want to reboot now? {y|n} yYou must reboot the node in order to use the newly installed software.
Clear the configuration on a controller module
Before using a new controller module in the MetroCluster configuration, you must clear the existing configuration.
If necessary, halt the node to display the
LOADERprompt:halt -
At the
LOADERprompt, set the environmental variables to default values:set-defaults -
Save the environment:
saveenv -
At the
LOADERprompt, launch the boot menu:boot_ontap menu -
At the boot menu prompt, clear the configuration:
wipeconfigRespond
yesto the confirmation prompt.The node reboots and the boot menu is displayed again.
At the boot menu, select option 5 to boot the system into Maintenance mode.
Respond
Restore the HBA configuration
Depending on the presence and configuration of HBA cards in the controller module, you need to configure them correctly for your site's usage.
In Maintenance mode configure the settings for any HBAs in the system:
Check the current settings of the ports:
ucadmin show -
Update the port settings as needed.
If you have this type of HBA and desired mode…
Use this command…
CNA FC
ucadmin modify -m fc -t initiator adapter-nameCNA Ethernet
ucadmin modify -mode cna adapter-nameFC target
fcadmin config -t target adapter-nameFC initiator
fcadmin config -t initiator adapter-name -
Exit Maintenance mode:
haltAfter you run the command, wait until the node stops at the LOADER prompt.
Boot the node back into Maintenance mode to enable the configuration changes to take effect:
boot_ontap maint -
Verify the changes you made:
If you have this type of HBA…
Use this command…
CNA
ucadmin showFC
fcadmin show
Reassign root aggregate disks
Reassign the root aggregate disks to the new controller module, using the sysids gathered earlier
This task is performed in Maintenance mode.
The old system IDs were identified in Gather information before the upgrade.
The examples in this procedure use controllers with the following system IDs:
Node |
Old system ID |
New system ID |
node_B_1 |
4068741254 |
1574774970 |
Cable all other connections to the new controller modules (FC-VI, storage, cluster interconnect, etc.).
Halt the system and boot to Maintenance mode from the LOADER prompt:
boot_ontap maint -
Display the disks owned by node_B_1-old:
disk show -aThe command output shows the system ID of the new controller module (1574774970). However, the root aggregate disks are still owned by the old system ID (4068741254). This example does not show drives owned by other nodes in the MetroCluster configuration.
*> disk show -a Local System ID: 1574774970 DISK OWNER POOL SERIAL NUMBER HOME DR HOME ------------ ------------- ----- ------------- ------------- ------------- ... rr18:9.126L44 node_B_1-old(4068741254) Pool1 PZHYN0MD node_B_1-old(4068741254) node_B_1-old(4068741254) rr18:9.126L49 node_B_1-old(4068741254) Pool1 PPG3J5HA node_B_1-old(4068741254) node_B_1-old(4068741254) rr18:8.126L21 node_B_1-old(4068741254) Pool1 PZHTDSZD node_B_1-old(4068741254) node_B_1-old(4068741254) rr18:8.126L2 node_B_1-old(4068741254) Pool0 S0M1J2CF node_B_1-old(4068741254) node_B_1-old(4068741254) rr18:8.126L3 node_B_1-old(4068741254) Pool0 S0M0CQM5 node_B_1-old(4068741254) node_B_1-old(4068741254) rr18:9.126L27 node_B_1-old(4068741254) Pool0 S0M1PSDW node_B_1-old(4068741254) node_B_1-old(4068741254) ...
Reassign the root aggregate disks on the drive shelves to the new controller:
disk reassign -s old-sysid -d new-sysidThe following example shows reassignment of drives:
*> disk reassign -s 4068741254 -d 1574774970 Partner node must not be in Takeover mode during disk reassignment from maintenance mode. Serious problems could result!! Do not proceed with reassignment if the partner is in takeover mode. Abort reassignment (y/n)? n After the node becomes operational, you must perform a takeover and giveback of the HA partner node to ensure disk reassignment is successful. Do you want to continue (y/n)? Jul 14 19:23:49 [localhost:config.bridge.extra.port:error]: Both FC ports of FC-to-SAS bridge rtp-fc02-41-rr18:9.126L0 S/N [FB7500N107692] are attached to this controller. y Disk ownership will be updated on all disks previously belonging to Filer with sysid 4068741254. Do you want to continue (y/n)? y
Check that all disks are reassigned as expected:
disk show*> disk show Local System ID: 1574774970 DISK OWNER POOL SERIAL NUMBER HOME DR HOME ------------ ------------- ----- ------------- ------------- ------------- rr18:8.126L18 node_B_1-new(1574774970) Pool1 PZHYN0MD node_B_1-new(1574774970) node_B_1-new(1574774970) rr18:9.126L49 node_B_1-new(1574774970) Pool1 PPG3J5HA node_B_1-new(1574774970) node_B_1-new(1574774970) rr18:8.126L21 node_B_1-new(1574774970) Pool1 PZHTDSZD node_B_1-new(1574774970) node_B_1-new(1574774970) rr18:8.126L2 node_B_1-new(1574774970) Pool0 S0M1J2CF node_B_1-new(1574774970) node_B_1-new(1574774970) rr18:9.126L29 node_B_1-new(1574774970) Pool0 S0M0CQM5 node_B_1-new(1574774970) node_B_1-new(1574774970) rr18:8.126L1 node_B_1-new(1574774970) Pool0 S0M1PSDW node_B_1-new(1574774970) node_B_1-new(1574774970) *>
Display the aggregate status:
aggr status*> aggr status Aggr State Status Options aggr0_node_b_1-root online raid_dp, aggr root, nosnap=on, mirrored mirror_resync_priority=high(fixed) fast zeroed 64-bit -
Repeat the above steps on the partner node (node_B_2-new).
Boot up the new controllers
You must reboot the controllers from the boot menu to update the controller flash image. Additional steps are required if encryption is configured.
You can reconfigure VLANs and interface groups. If required, manually modify the ports for the cluster LIFs and broadcast domain details before resuming the operation by using the system controller replace resume command.
This task must be performed on all the new controllers.
Halt the node:
halt -
If external key manager is configured, set the related bootargs:
setenv bootarg.kmip.init.ipaddr ip-addresssetenv bootarg.kmip.init.netmask netmasksetenv bootarg.kmip.init.gateway gateway-addresssetenv bootarg.kmip.init.interface interface-id -
Display the boot menu:
boot_ontap menu -
If the admin SVM of the MetroCluster system is configured with a key manager, select the correct boot menu option for your key management configuration.
If you are using…
Select this boot menu option…
Onboard key management
Option
10Follow the prompts to provide the following inputs to recover and restore the key manager configuration:
The Onboard Key Manager backup and passphrase
External key management
Option
11Follow the prompts to provide the following inputs to recover and restore the key manager configuration:
The username and password if one is associated with the chosen primary key server
Note: Although the admin SVM can have up to four primary key servers, only information for one primary key server can be specified during the recovery process.
If autoboot is enabled, interrupt autoboot by pressing Ctrl-C.
From the boot menu, run option “6”.
Option “6” will reboot the node twice before completing. Respond “y” to the system id change prompts. Wait for the second reboot messages:
Successfully restored env file from boot media... Rebooting to load the restored env file...
Double-check that the partner-sysid is correct:
printenv partner-sysidIf the partner-sysid is not correct, set it:
setenv partner-sysid partner-sysID -
If root volume encryption is used, select the boot menu option again for your key management configuration.
If you are using…
Option
Option
Depending on the key manager setting, perform the recovery procedure by selecting option “10” or option “11”, followed by option “6” at the first boot menu prompt. To boot the nodes completely, you might need to repeat the recovery procedure continued by option “1” (normal boot).
Boot the nodes:
boot_ontap -
Wait for the replaced nodes to boot up.
If either node is in takeover mode, perform a giveback using the
storage failover givebackcommand. -
Verify that all ports are in a broadcast domain:
View the broadcast domains:
Add any ports to a broadcast domain as needed.
Add the physical port that will host the intercluster LIFs to the corresponding broadcast domain.
Modify intercluster LIFs to use the new physical port as home port.
After the intercluster LIFs are up, check the cluster peer status and re-establish cluster peering as needed.
You may need to reconfigure cluster peering.
Recreate VLANs and interface groups as needed.
VLAN and interface group membership might be different than that of the old node.
Verify that the partner cluster is reachable and that the configuration is successfully resynchronized on the partner cluster:
metrocluster switchback -simulate true
If encryption is used, restore the keys using the correct command for your key management configuration.
If you are using…
Use this command…
security key-manager onboard syncFor more information, see Restore onboard key management encryption keys.
security key-manager external restore -vserver <admin-svm> -key-server <host_name|IP_address:port>For more information, see Restore external key management encryption keys.
Before you resume the operation, verify that the MetroCluster is configured correctly. Check the node status:
metrocluster node showVerify that the new nodes (site_B) are in Waiting for switchback state from site_A.
Resume the operation:
Complete the upgrade
The automation operation runs verification system checks and then pauses so you can verify the network reachability. After verification, the resource regain phase is initiated and the automation operation executes switchback at site A and pauses at the post upgrade checks. After you resume the automation operation, it performs the post upgrade checks and if no errors are detected, marks the upgrade as complete.
Verify the network reachability by following the console message.
After you complete the verification, resume the operation:
system controller replace resume -
The automation operation performs switchback at site A and the post upgrade checks. When the operation pauses, manually check the SAN LIF status and verify the network configuration by following the console message.
Check the post upgrade checks status:
system controller replace showIf the post upgrade checks did not report any errors, the upgrade is complete.
After you complete the controller upgrade, log in at site B and verify that the replaced controllers are configured correctly.
Upgrade the nodes on cluster_A
You must repeat the upgrade tasks to upgrade the nodes on cluster_A at site A.
Repeat the steps to upgrade the nodes on cluster_A, beginning with prepare for the upgrade.
When you repeat the procedure, all example references to the clusters and nodes are reversed.
Restoring Tiebreaker monitoring
If the MetroCluster configuration was previously configured for monitoring by the Tiebreaker software, you can restore the Tiebreaker connection.
Use the steps in Add MetroCluster configurations.
