Preparing for the upgrade
Before upgrading to an HA pair, you must verify that your system meets all requirements and that you have all of the necessary information.
Identify unassigned disks or spare disks that you can assign to the new controller module using the following commands:
storage disk show -container-type spare -
storage disk show -container-type unassigned
Complete the following substeps:
Determine where the aggregates for the existing node are located:
storage aggregate show -
If disk ownership automatic assignment is on, turn it off:
storage disk option modify -node node_name -autoassign off -
Remove ownership on disks that do not have aggregates on them:
storage disk removeowner disk_name -
Repeat the previous step for as many disks as you need for the new node.
Verify that you have cables ready for the following connections:
Cluster connections
If you are creating a two-node switchless cluster, you require two cables to connect the controller modules. Otherwise, you require a minimum of four cables, two for each controller module connection to the cluster-network switch. Other systems (like the 80xx series) have defaults of either four or six cluster connections.
HA interconnect connections, if the system is in a dual-chassis HA pair
Verify that you have a serial port console available for the controller modules.
Verify that your environment meets the site and system requirements.
Gather all of the IP addresses and other network parameters for the new controller module.
