ONTAP MetroCluster
Hot-adding a SAS disk shelf in a direct-attached MetroCluster FC configuration using SAS optical cables
Contributors netapp-aoife netapp-ivanad
You can use SAS optical cables to hot-add a SAS disk shelf to an existing stack of SAS disk shelves in a direct-attached MetroCluster FC configuration, or as a new stack to a SAS HBA or an onboard SAS port on the controller.
  • This procedure is nondisruptive and takes approximately two hours to complete.
  • You need the admin password and access to an FTP or SCP server.
This task applies to a MetroCluster FC configuration in which the storage is connected directly to the storage controllers with SAS cables. It does not apply to MetroCluster FC configurations using FC-to-SAS bridges or FC switch fabrics.
Steps
  1. Follow the instructions for hot-adding a SAS disk shelf in the Installation Guide for your disk shelf model to perform the following tasks to hot-add a disk shelf:
    1. Install a disk shelf for a hot-add.
    2. Turn on the power supplies and set the shelf ID for a hot-add.
    3. Cable the hot-added disk shelf.
    4. Verify SAS connectivity.
