ONTAP MetroCluster
Required MetroCluster IP configuration components and naming conventions
Contributors netapp-aoife netapp-aaron-holt netapp-martyh netapp-aherbin netapp-pcarriga netapp-driley netapp-folivia netapp-thomi NetAppZacharyWambold
Identify the required and supported hardware and software components for a MetroCluster IP configuration. Review the naming conventions that documentation examples use for the components.
Supported software and hardware
The hardware and software must be supported for the MetroCluster IP configuration.
When using AFF systems, all controller modules in the MetroCluster configuration must be configured as AFF systems.
Hardware redundancy requirements in a MetroCluster IP configuration
Because of the hardware redundancy in the MetroCluster IP configuration, there are two of each component at each site. The sites are arbitrarily assigned the letters A and B, and the individual components are arbitrarily assigned the numbers 1 and 2.
ONTAP cluster requirements in a MetroCluster IP configuration
MetroCluster IP configurations require two ONTAP clusters, one at each MetroCluster site.
Naming must be unique within the MetroCluster configuration.
Example names:
  • Site A: cluster_A
  • Site B: cluster_B
IP switch requirements in a MetroCluster IP configuration
MetroCluster IP configurations require four IP switches. The four switches form two switch storage fabrics that provide the ISL between each of the clusters in the MetroCluster IP configuration.
The IP switches also provide intracluster communication among the controller modules in each cluster.
Example names:
  • Site A: cluster_A
    • IP_switch_A_1
    • IP_switch_A_2
  • Site B: cluster_B
    • IP_switch_B_1
    • IP_switch_B_2
Controller module requirements in a MetroCluster IP configuration
MetroCluster IP configurations require four or eight controller modules.
The controller modules at each site form an HA pair. Each controller module has a DR partner at the other site.
Each controller module must be running the same ONTAP version. Supported platform models depend on the ONTAP version:
  • New MetroCluster IP installations on FAS systems are not supported in ONTAP 9.4.
    Existing MetroCluster IP configurations on FAS systems can be upgraded to ONTAP 9.4.
  • Beginning with ONTAP 9.5, new MetroCluster IP installations on FAS systems are supported.
  • Beginning with ONTAP 9.4, controller modules configured for ADP are supported.
Example names
The following example names are used in the documentation:
  • Site A: cluster_A
    • controller_A_1
    • controller_A_2
  • Site B: cluster_B
    • controller_B_1
    • controller_B_2
Gigabit Ethernet adapter requirements in a MetroCluster IP configuration
MetroCluster IP configurations use a 40/100 Gbps or 10/25 Gbps Ethernet adapter for the IP interfaces to the IP switches used for the MetroCluster IP fabric.
Note Onboard ports are built into the controller hardware (Slot 0) and can't be replaced, so the required slot for adapter is not applicable.
Platform model
Required Gigabit Ethernet adapter
Required slot for adapter
Ports
AFF A900, ASA A900, and FAS9500
X91146A
Slot 5, Slot 7
e5b, e7b
Note: Ports e5a and e7a can only be used for intercluster LIFs. You cannot use these ports for a data LIF.
AFF A700 and FAS9000
X91146A-C
Slot 5
e5a, e5b
AFF A800, AFF C800, ASA A800, and ASA C800
X1146A/onboard ports
Slot 1/Not applicable for onboard ports
e0b. e1b
FAS8300, AFF A400, ASA A400, ASA C400, AFF C400
X1146A
Slot 1
e1a, e1b
AFF A300, FAS8200
X1116A
Slot 1
e1a, e1b
FAS2750, AFF A150, ASA A150, AFF A220
Onboard ports
Not applicable
e0a, e0b
FAS500f, AFF A250, ASA A250, ASA C250, AFF C250
Onboard ports
Not applicable
e0c, e0d
AFF A320
Onboard ports
Not applicable
e0g, e0h
AFF A70, FAS70, AFF C80
X50132A
Slot 2
e2a, e2b
AFF A90, AFF A1K, FAS90
X50132A
Slot 2, Slot 3
e2b, e3b
Note: Ports e2a and e3a must remain unused. Using these ports for front-end networks or peering is not supported.
AFF A50
X60134A
Slot 2
e2a, e2b
AFF A30, AFF C30, AFF C60, FAS50
X60134A
Slot 2
e2a, e2b
Note: 25 GbE speed requires the MAM1Q00A-QSA28 transceiver adapter.
AFF A20
X60132A
Slot 4, Slot 2
e2b, e4b
Pool and drive requirements (minimum supported)
A four-node MetroCluster IP configuration requires the minimum configuration at each site:
  • Each node has at least one local pool and one remote pool at the site.
  • At least seven drives in each pool.
    In a four-node MetroCluster configuration with a single mirrored data aggregate per node, the minimum configuration requires 24 disks at the site.
    Note Aggregate names must be unique across the MetroCluster sites. This means that you cannot have two different aggregates with the same name on site A and site B.
In a minimum supported configuration, each pool has the following drive layout:
  • Three root drives
  • Three data drives
  • One spare drive
In a minimum supported configuration, at least one shelf is needed per site.
MetroCluster configurations support RAID-DP, RAID4, and RAID-TEC.
Note Beginning with ONTAP 9.4, MetroCluster IP configurations support new installations using automatic disk assignment and ADP (Advanced Drive Partitioning). Refer to Considerations for automatic drive assignment and ADP systems for more information.
Drive location considerations for partially populated shelves
For correct auto-assignment of drives when using shelves that are half populated (12 drives in a 24-drive shelf), drives should be located in slots 0-5 and 18-23.
In a configuration with a partially populated shelf, the drives must be evenly distributed in the four quadrants of the shelf.
Drive location considerations for AFF A800 internal drives
For correct implementation of the ADP feature, the AFF A800 system disk slots must be divided into quarters and the disks must be located symmetrically in the quarters.
An AFF A800 system has 48 drive bays. The bays can be divided into quarters:
  • Quarter one:
    • Bays 0 - 5
    • Bays 24 - 29
  • Quarter two:
    • Bays 6 - 11
    • Bays 30 - 35
  • Quarter three:
    • Bays 12 - 17
    • Bays 36 - 41
  • Quarter four:
    • Bays 18 - 23
    • Bays 42 - 47
If this system is populated with 16 drives, they must be symmetrically distributed among the four quarters:
  • Four drives in the first quarter: 0, 1, 2, 3
  • Four drives in the second quarter: 6, 7, 8, 9
  • Four drives in the third quarter: 12, 13, 14, 15
  • Four drives in the fourth quarter: 18, 19, 20, 21
