Alert messages and tool support during MetroCluster transition
You may notice alert messages during transition. These alerts can be safely ignored. Also, some tools are not available during transition.
ARS may alert during transition.
These alerts can be ignored and should disappear once the transition has finished.
OnCommand Unified Manager may alert during transition.
Config Advisor is not supported during transition.
System Manager is not supported during transition.
