ONTAP MetroCluster
Choose a MetroCluster expansion procedure
Contributors netapp-folivia
The expansion procedure you use depends on the type of MetroCluster configuration and the ONTAP version.
An expansion procedure involves adding new controllers and storage to the MetroCluster configuration. The expansion must maintain an even number of controllers on each site and the procedure you use depends on the number of nodes in the original MetroCluster configuration.
Expansion method Configuration type ONTAP version Procedure
Method: Expand a two-node MetroCluster FC to four
Two-node FC
ONTAP 9 and later (platforms must be supported in ONTAP 9.2 and later)
Method: Expand a four-node MetroCluster FC to eight
Four-node FC
ONTAP 9 or later
Method: Expand a four-node MetroCluster IP to eight
Four-node IP
ONTAP 9.9.1 and later
