Boot the new MetroCluster IP controllers and restore LIF configuration
Boot the new controllers and verify that LIFs are hosted on appropriate nodes and ports before resuming the operation by using the system controller replace resume command.
Boot the new controllers,verify that the bootarg variables are correct and if needed, perform the encryption recovery steps.
This task must be performed on all the new controllers.
Halt the node:
halt -
If external key manager is configured, set the related bootargs:
setenv bootarg.kmip.init.ipaddr <ip-address>setenv bootarg.kmip.init.netmask <netmask>setenv bootarg.kmip.init.gateway <gateway-address>setenv bootarg.kmip.init.interface <interface-id> -
Check if the partner-sysid is correct:
printenv partner-sysidIf the partner-sysid is not correct, set it:
setenv partner-sysid <partner-sysID> -
Display the boot menu:
boot_ontap menu -
If the admin SVM of the MetroCluster system is configured with a key manager, select the correct boot menu option for your key management configuration.
If you are using…
Select this boot menu option…
Onboard key management
Option
10Follow the prompts to provide the following inputs to recover and restore the key manager configuration:
The Onboard Key Manager backup and passphrase
External key management
Option
11Follow the prompts to provide the following inputs to recover and restore the key manager configuration:
The port number and address of one of the primary key servers for the admin SVM
The username and password if one is associated with the chosen primary key server
The keystore UUID for the admin SVM (required in ONTAP 9.16.1 or later)
Note: Although the admin SVM can have up to four primary key servers, only information for one primary key server can be specified during the recovery process.
From the boot menu, run option “6”.
Option “6” reboots the node twice before the process completes. Respond with “y” to the system ID change prompts. Wait for the second reboot messages:
Successfully restored env file from boot media... Rebooting to load the restored env file...
During one of the reboots after option “6”, the confirmation prompt
Override system ID? {y|n}appears. Entery. -
At the
LOADERprompt, verify the bootarg values and update the values as needed.Use the steps in Set the MetroCluster IP bootarg variables.
Verify that the partner-sysid is correct:
If root volume encryption is used, select the boot menu option again for your key management configuration.
If you are using…
Option
Option
Depending on the key manager setting, perform the recovery procedure by selecting option “10” or option “11”, followed by option “6” at the first boot menu prompt. To boot the nodes completely, you might need to repeat the recovery procedure continued by option “1” (normal boot).
When you run the boot menu option 6, the MetroCluster bootarg values might need to be reset. Refer to Set the MetroCluster IP bootarg variables. -
Boot the nodes:
boot_ontap -
Wait for the replaced nodes to boot up.
If either node is in takeover mode, perform a giveback using the
storage failover givebackcommand. -
Verify that all ports are in a broadcast domain:
View the broadcast domains:
network port broadcast-domain show -
If a new broadcast domain is created for the data ports on the newly upgraded controllers, delete the broadcast domain:
Only delete the new broadcast domain. Do not delete any of the broadcast domains that existed before starting the upgrade. broadcast-domain delete -broadcast-domain <broadcast_domain_name> -
Add any ports to a broadcast domain as needed.
Add the physical port that will host the intercluster LIFs to the corresponding broadcast domain.
Modify intercluster LIFs to use the new physical port as home port.
After the intercluster LIFs are up, check the cluster peer status and reestablish cluster peering as needed.
You might need to reconfigure cluster peering.
Recreate VLANs and interface groups as needed.
VLAN and interface group membership might be different than that of the old node.
Verify that the partner cluster is reachable and that the configuration is successfully resynchronized on the partner cluster:
metrocluster switchback -simulate true
If encryption is used, restore the keys using the correct command for your key management configuration.
If you are using…
Use this command…
security key-manager onboard syncFor more information, see Restore onboard key management encryption keys.
security key-manager external restore -vserver <admin-svm> -key-server <host_name|IP_address:port>For more information, see Restore external key management encryption keys.
Verify that the MetroCluster is configured correctly. Check the node status:
metrocluster node showVerify that the new nodes (site_B) are in Waiting for switchback state from site_A.
Verify and restore LIF configuration
Verify that LIFs are hosted on appropriate nodes before you proceed with the automated switchback operation.
This task is performed on site_B.
You must verify that the location of the data LIFs is correct on the new nodes before you perform a switchback. When you switchback the configuration, ONTAP attempts to resume traffic on the home port used by the LIFs. I/O failure can occur when the home port connection to the switch port and VLAN is incorrect. |
Verify that LIFs are hosted on the appropriate node and ports before switchback.
Change to the advanced privilege level:
set -privilege advanced -
Display the LIFs, and confirm that each data LIF is using the correct home port:
network interface show -
Modify any LIFs that aren't using the correct home port:
network interface modify -vserver <svm-name> -lif <data-lif> -home-port <port-id>If the command returns an error, you can override the port configuration:
vserver config override -command "network interface modify -vserver <svm-name> -home-port <active_port_after_upgrade> -lif <lif_name> -home-node <new_node_name>"When entering the network interface modify command within the
vserver config overridecommand, you cannot use the tab autocomplete feature. You can create the networkinterface modifyusing autocomplete and then enclose it in thevserver config overridecommand. -
Confirm that all data LIFs are now on the correct home port:
Return to the admin privilege level:
set -privilege admin
Revert the interfaces to their home node:
network interface revert * -vserver <svm-name>Perform this step on all SVMs as required.
Resume the operation:
