Restore HBA configuration and set HA state on new MetroCluster IP controllers
Configure the HBA cards in the controller module and verify and set the HA state of the controller and chassis.
Restore the HBA configuration
Depending on the presence and configuration of HBA cards in the controller module, you need to configure them correctly for your site.
In Maintenance mode, configure the settings for any HBAs in the system:
Check the current settings of the ports:
ucadmin show -
Update the port settings as needed.
If you have this type of HBA and desired mode…
Use this command…
CNA FC
ucadmin modify -m fc -t initiator <adapter-name>CNA Ethernet
ucadmin modify -mode cna <adapter-name>FC target
fcadmin config -t target <adapter-name>FC initiator
fcadmin config -t initiator <adapter-name> -
Exit Maintenance mode:
haltAfter you run the command, wait until the node stops at the
LOADERprompt. -
Boot the node back into Maintenance mode to apply the configuration changes:
boot_ontap maint -
Verify the changes:
If you have this type of HBA…
Use this command…
CNA
ucadmin showFC
fcadmin show
Set the HA state on the new controllers and chassis
You must verify the HA state of the controllers and chassis, and, if necessary, update the state to match your system configuration.
In Maintenance mode, display the HA state of the controller module and chassis:
ha-config showThe HA state for all components should be
mccip. -
If the displayed system state of the controller or chassis is not correct, set the HA state:
ha-config modify controller mccipha-config modify chassis mccip -
Verify and modify the Ethernet ports connected to NS224 shelves or storage switches.
Verify the Ethernet ports connected to NS224 shelves or storage switches:
storage port show -
Set all Ethernet ports connected to Ethernet shelves or storage switches, including shared switches for storage and cluster, to
storagemode:storage port modify -p <port> -m storageExample:
*> storage port modify -p e5b -m storage Changing NVMe-oF port e5b to storage mode
This must be set on all affected ports for a successful upgrade. Disks from the shelves attached to the Ethernet ports are reported in the
sysconfig -voutput.Refer to the Hardware Universe for information on the storage ports for the system you are upgrading to.
Verify that
storagemode is set and confirm that the ports are in the online state:storage port show
Halt the node:
haltThe node should stop at the
LOADER>prompt. -
On each node, check the system date, time, and time zone:
show date -
If necessary, set the date in UTC or GMT:
set date <mm/dd/yyyy> -
Check the time by using the following command at the boot environment prompt:
show time -
If necessary, set the time in UTC or GMT:
set time <hh:mm:ss> -
Save the settings:
saveenv -
Gather environment variables:
printenv
Remove internal drives from the chassis on the new controller
When you upgrade from a system that only has external drives to a system that has external and internal drives (disks and controllers in the same chassis), you need to remove or unseat all internal drives from the new system until you have completed the upgrade.
This task is mandatory for a successful controller upgrade on affected systems. |
To determine if your upgrade combination is affected, refer to the table in Supported MetroCluster IP controller upgrades using "system controller replace" commands. If your upgrade combination is marked with Note 2, you must remove or unseat the internal drives from the new system.
After you complete this task, no internal drives should be accessible. You'll add the drives to the new controller later in the procedure.
