Choose a MetroCluster upgrade, system refresh, or expansion method
Depending on the scope of the equipment upgrade, you choose a controller upgrade procedure, a system refresh procedure, or an expansion procedure.
Controller upgrade procedures apply only to the controller modules. The controllers are replaced with a new controller model.
The storage shelf models are not upgraded.
In switchover and switchback procedures, the MetroCluster switchover operation is used to provide nondisruptive service to clients while the controller modules on the partner cluster are upgraded.
In an ARL-based controller upgrade procedure, the aggregate relocation operations are used to nondisruptively move data from the old configuration to the new, upgraded configuration.
Refresh procedures apply to the controllers and the storage shelves.
In the refresh procedures, new controllers and shelves are added to the MetroCluster configuration, creating a second DR group, and then data is nondisruptively migrated to the new nodes.
The original controllers are then retired.
Expansion procedures add additional controllers and shelves to the MetroCluster configuration without removing any.
The procedure you use depends on the type of MetroCluster and number of existing controllers.
If SVM migration is in progress, wait until all migration processes are complete before initiating the controller upgrade or system refresh procedures. Don't start new SVM migrate operations during the upgrade or refresh process. |
Upgrade type |
Go to… |
Controller upgrade |
System refresh |
Expansion |
