Upgrading or downgrading the firmware on a Cisco FC switch
To upgrade or downgrade the firmware on a Cisco FC switch you must use the Cisco-specific commands to disable the switch, perform and verify the upgrade, and reboot and reenable the switch.
Confirm that you have checked and performed the following tasks for your configuration:
The system is properly cabled.
All paths to the storage shelves are available.
The disk shelf stacks are stable.
The FC switch fabric are healthy.
All components in the system are healthy.
The system is operating normally.
You have the admin password and access to an FTP or SCP server.
Console logging is enabled.
The switch fabric is disabled during the firmware upgrade or downgrade and the MetroCluster configuration relies on the second fabric to continue operation.
You must repeat this task on each of the switch fabrics in succession to ensure that all switches are running the same firmware version.
You must have the firmware files.
This procedure is nondisruptive and takes approximately one hour to complete. |
Log in to each of the switches in the fabric.
In the examples, the switches are called FC_switch_A_1 and FC_switch_B_1.
Determine whether there is enough space in the bootflash directory on each switch:
dir bootflash
If not, delete the unwanted firmware files by using the
delete bootflash:file_name
command. -
Copy the kickstart and system files to the switches:
copy source_filetarget_file
In the following example, the kickstart file (
m9200-s2ek9-kickstart-mz.5.2.1.bin
) and the system file (m9200-s2ek9-mz.5.2.1.bin
) are located on the FTP server 10.10.10.55 in the/firmware/
path.The following example shows the commands issued on FC_switch_A_1:
FC_switch_A_1# copy ftp://10.10.10.55/firmware/m9200-s2ek9-kickstart-mz.5.2.1.bin bootflash:m9200-s2ek9-kickstart-mz.5.2.1.bin FC_switch_A_1# copy ftp://10.10.10.55/firmware/m9200-s2ek9-mz.5.2.1.bin bootflash:m9200-s2ek9-mz.5.2.1.bin
Disable all of the VSANs on both of the switches in this fabric.
Use the following procedure to disable the VSANs:
Open the config terminal:
config t
Enter:
vsan database
Check the state of the VSANs:
show vsan
All VSANs must be active.
Suspend the VSANs:
vsan vsan-num suspend
Example:
vsan 10 suspend
Check the state of the VSANs again:
show vsan
All VSANs must be suspended. -
Exit the config terminal:
end
Save the configuration.
copy running-config startup-config
The following example displays the output for FC_switch_A_1:
FC_switch_A_1# config t Enter configuration commands, one per line. End with CNTL/Z. FC_switch_A_1(config)# vsan database FC_switch_A_1(config-vsan-db)# show vsan vsan 1 information name:VSAN0001 state:active interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:up vsan 30 information name:MC1_FCVI_2_30 state:active interoperability mode:default loadbalancing:src-id/dst-id operational state:up vsan 40 information name:MC1_STOR_2_40 state:active interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:up vsan 70 information name:MC2_FCVI_2_70 state:active interoperability mode:default loadbalancing:src-id/dst-id operational state:up vsan 80 information name:MC2_STOR_2_80 state:active interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:up vsan 4079:evfp_isolated_vsan vsan 4094:isolated_vsan FC_switch_A_1(config-vsan-db)# vsan 1 suspend FC_switch_A_1(config-vsan-db)# vsan 30 suspend FC_switch_A_1(config-vsan-db)# vsan 40 suspend FC_switch_A_1(config-vsan-db)# vsan 70 suspend FC_switch_A_1(config-vsan-db)# vsan 80 suspend FC_switch_A_1(config-vsan-db)# end FC_switch_A_1# FC_switch_A_1# show vsan vsan 1 information name:VSAN0001 state:suspended interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:down vsan 30 information name:MC1_FCVI_2_30 state:suspended interoperability mode:default loadbalancing:src-id/dst-id operational state:down vsan 40 information name:MC1_STOR_2_40 state:suspended interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:down vsan 70 information name:MC2_FCVI_2_70 state:suspended interoperability mode:default loadbalancing:src-id/dst-id operational state:down vsan 80 information name:MC2_STOR_2_80 state:suspended interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:down vsan 4079:evfp_isolated_vsan vsan 4094:isolated_vsan
Install the desired firmware on the switches:
install all system bootflash:systemfile_name kickstart bootflash:kickstartfile_name
FC_switch_A_1# install all system bootflash:m9200-s2ek9-mz.5.2.1.bin kickstart bootflash:m9200-s2ek9-kickstart-mz.5.2.1.bin Enter Yes to confirm the installation.
Check the version of the firmware on each switch to make sure the correct version was installed:
show version
Enable all of the VSANs on both of the switches in this fabric.
Use the following procedure to enable the VSANs:
config t
Enter:
vsan database
show vsan
The VSANs must be suspended.
Activate the VSANs:
no vsan vsan-num suspend
Example:
no vsan 10 suspend
show vsan
end
Save the configuration:
FC_switch_A_1# config t Enter configuration commands, one per line. End with CNTL/Z. FC_switch_A_1(config)# vsan database FC_switch_A_1(config-vsan-db)# show vsan vsan 1 information name:VSAN0001 state:suspended interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:down vsan 30 information name:MC1_FCVI_2_30 state:suspended interoperability mode:default loadbalancing:src-id/dst-id operational state:down vsan 40 information name:MC1_STOR_2_40 state:suspended interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:down vsan 70 information name:MC2_FCVI_2_70 state:suspended interoperability mode:default loadbalancing:src-id/dst-id operational state:down vsan 80 information name:MC2_STOR_2_80 state:suspended interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:down vsan 4079:evfp_isolated_vsan vsan 4094:isolated_vsan FC_switch_A_1(config-vsan-db)# no vsan 1 suspend FC_switch_A_1(config-vsan-db)# no vsan 30 suspend FC_switch_A_1(config-vsan-db)# no vsan 40 suspend FC_switch_A_1(config-vsan-db)# no vsan 70 suspend FC_switch_A_1(config-vsan-db)# no vsan 80 suspend FC_switch_A_1(config-vsan-db)# FC_switch_A_1(config-vsan-db)# show vsan vsan 1 information name:VSAN0001 state:active interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:up vsan 30 information name:MC1_FCVI_2_30 state:active interoperability mode:default loadbalancing:src-id/dst-id operational state:up vsan 40 information name:MC1_STOR_2_40 state:active interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:up vsan 70 information name:MC2_FCVI_2_70 state:active interoperability mode:default loadbalancing:src-id/dst-id operational state:up vsan 80 information name:MC2_STOR_2_80 state:active interoperability mode:default loadbalancing:src-id/dst-id/oxid operational state:up vsan 4079:evfp_isolated_vsan vsan 4094:isolated_vsan FC_switch_A_1(config-vsan-db)# end FC_switch_A_1#
Verify the operation of the MetroCluster configuration in ONTAP:
Check whether the system is multipathed:
node run -node node-name sysconfig -a
Check for any health alerts on both clusters:
system health alert show
Confirm the MetroCluster configuration and that the operational mode is normal:
metrocluster show
Perform a MetroCluster check:
metrocluster check run
Display the results of the MetroCluster check:
metrocluster check show
Check for any health alerts on the switches (if present):
storage switch show
Run Config Advisor.
After running Config Advisor, review the tool's output and follow the recommendations in the output to address any issues discovered.
Repeat this procedure for the second switch fabric.
