Disruptively transitioning from a two-node MetroCluster FC to a four-node MetroCluster IP configuration (ONTAP 9.8 and later)
Beginning with ONTAP 9.8, you can transition workloads and data from an existing two-node MetroCluster FC configuration to a new four-node MetroCluster IP configuration. Disk shelves from the MetroCluster FC nodes are moved to the IP nodes.
The following illustration provides a simplified view of the configuration before and after this transition procedure.
This procedure is supported on systems running ONTAP 9.8 and later.
This procedure is disruptive.
This procedure applies only to a two-node MetroCluster FC configuration.
If you have a four-node MetroCluster FC configuration, see Choosing your transition procedure.
ADP is not supported on the four-node MetroCluster IP configuration created by this procedure.
You must meet all requirements and follow all steps in the procedure.
The existing storage shelves are moved to the new MetroCluster IP nodes.
Additional storage shelves can be added to the configuration if necessary.
