ONTAP MetroCluster
Complete the MetroCluster transition
Contributors netapp-aoife netapp-ranuk
To complete the transition you must verify the operation of the new MetroCluster IP configuration.
  1. Verify the MetroCluster IP configuration.
    You must perform this step on each cluster in advanced privilege mode.
    The following example shows the output for cluster_A.
    cluster_A::> cluster show
    Node                 Health  Eligibility   Epsilon
    node_A_1-IP          true    true          false
    node_A_2-IP          true    true          false
    2 entries were displayed.
    cluster_A::>
    The following example shows the output for cluster_B.
    cluster_B::> cluster show
    node_B_1-IP          true    true          false
    node_B_2-IP          true    true          false
    cluster_B::>
  2. Enable cluster HA and storage failover.
    You must perform this step on each cluster.
  3. Verify that cluster HA capability is enabled.
    cluster_A::> cluster ha show
    High Availability Configured: true
    cluster_A::>
    cluster_A::> storage  failover show
                                  Takeover
    Node           Partner        Possible State Description
    node_A_1-IP    node_A_2-IP    true     Connected to node_A_2-IP
    node_A_2-IP    node_A_1-IP    true     Connected to node_A_1-IP
    cluster_A::>
  4. Disable MetroCluster transition mode.
    1. Change to the advanced privilege level: set -privilege advanced
    2. Disable transition mode:metrocluster transition disable
    3. Return to the admin privilege level: set -privilege admin
    cluster_A::*> metrocluster transition disable
    cluster_A::*>
  5. Verify that transition is disabled:metrocluster transition show-mode
    You must perform these steps on both clusters.
    cluster_A::> metrocluster transition show-mode
    Transition Mode
    not-enabled
    cluster_A::>
    cluster_B::> metrocluster transition show-mode
    Transition Mode
    not-enabled
    cluster_B::>
  6. If you have an eight-node configuration, you must repeat the entire procedure starting from Prepare for transition from a MetroCluster FC to a MetroCluster IP configuration for each of the FC DR groups.
