ONTAP MetroCluster
Nondisruptive MetroCluster transition workflow
Contributors netapp-aoife netapp-martyh NetAppZacharyWambold
You must follow the specific workflow to ensure a successful nondisruptive transition. Choose the workflow for your configuration:
Four-node FC configuration transition workflow
The transition process begins with a healthy four-node MetroCluster FC configuration.
Transition FC nodes in DR group 1
The new MetroCluster IP nodes are added as a second DR group.
Transition DR group with both FC and IP nodes present
Data is transferred from the old DR group to the new DR group, and then the old nodes and their storage are removed from the configuration and decommissioned. The process ends with a four-node MetroCluster IP configuration.
Transition DR group 2 IP nodes
Eight-node FC configuration transition workflow
The transition process begins with a healthy eight-node MetroCluster FC configuration.
Eight-node MetroCluster FC configuration before transition
The new MetroCluster IP nodes are added as a third DR group.
Eight-node configuration with IP nodes added as third DR group
Data is transferred from DR_group_1-FC to DR_group_1-IP, and then the old nodes and their storage are removed from the configuration and decommissioned.
Note If you want to transition from an eight-node FC configuration to a four-node IP configuration, you must transition all the data in DR_group_1-FC and DR_group_2-FC to the new IP DR group (DR_group_1-IP). You can then decommission both FC DR groups. After the FC DR groups have been removed, the process ends with a four-node MetroCluster IP configuration.
Eight-node configuration after first DR group transition
Add the remaining MetroCluster IP nodes to the existing MetroCluster configuration. Repeat the process to transfer data from the DR_group_2-FC nodes to the DR_group_2-IP nodes.
Eight-node configuration with remaining IP nodes added
After removing DR_group_2-FC, the process ends with an eight-node MetroCluster IP configuration.
Eight-node MetroCluster IP configuration after transition
Transition process workflow
You will use the following workflow to transition the MetroCluster configuration.
Workflow for nondisruptive four-node transition
