ONTAP MetroCluster
Remove a DR group from a MetroCluster configuration
Contributors netapp-aoife netapp-folivia netapp-cgoff netapp-martyh netapp-thomi netapp-pcarriga netapp-ivanad
Beginning with ONTAP 9.8, you can remove a disaster recovery (DR) group from an eight-node MetroCluster configuration to create a four-node MetroCluster configuration.
Note You use these steps during the transition and system refresh workflows. You might have already completed some steps in this procedure as part of these workflows.
Enable console logging
NetApp strongly recommends that you enable console logging on the devices that you are using and take the following actions when performing this procedure:
Remove the DR group nodes from each cluster
This procedure is supported beginning with ONTAP 9.8. For systems running ONTAP 9.7 or earlier, see the Knowledge Base article: How to remove a DR group from a MetroCluster configuration.
About this task
  • You must perform this task on both clusters.
  • An eight-node configuration includes eight-nodes organized as two four-node DR groups.
    MetroCluster configuration with eight nodes in two DR groups
    When you remove a DR group, four nodes remain in the configuration.
    MetroCluster configuration with four nodes after DR group removal
Steps
  1. Prepare to remove the DR group if you have not already.
    1. Move all data volumes to another DR group.
    2. If the DR group to be removed has load-sharing mirror volumes, re-create all load-sharing mirror volumes in another DR group and delete them from the DR group to be removed.
    3. Move all MDV_CRS metadata volumes to another DR group by following the Moving a metadata volume in MetroCluster configurations procedure.
    4. Delete all MDV_aud metadata volumes that might exist in the DR group to be removed.
    5. Delete all data aggregates in the DR group to be removed:
      ClusterA::> storage aggregate show -node ClusterA-01, ClusterA-02 -fields aggregate ,node
      ClusterA::> aggr delete -aggregate aggregate_name
      ClusterB::> storage aggregate show -node ClusterB-01, ClusterB-02 -fields aggregate ,node
      ClusterB::> aggr delete -aggregate aggregate_name
      Note Root aggregates are not deleted.
    6. Migrate all NAS data LIFs that you use for NFS and CIFS (SMB) to home nodes in another DR group.
      network interface show -home-node <old_node>
      network interface migrate -vserver <svm_name> -lif <data_lif> -destination-node <new_node> -destination-port <port>
    7. Move the data LIFs to the new home node in another DR group. network interface modify -vserver <svm-name> -lif <data-lif> -home-node <new_node> -home-port <port>
    8. Migrate the cluster management LIF to a home node in another DR group.
      network interface show -role cluster-mgmt
      network interface modify -vserver <svm-name> -lif <cluster_mgmt> -home-node <new_node> -home-port <port-id>
      Note
      • Node management and inter-cluster LIFs are not migrated. Create new node management and inter-cluster LIFs on nodes of the DR group as required.
      • You cannot migrate or move FCP interfaces used for block access (SAN) between the nodes. Create new FCP interfaces as needed.
      • iSCSI SAN LIFs need to be down before the home node and home port can be updated.
    9. Transfer epsilon to a node in another DR group if required.
      ClusterA::> set advanced -prompt-timestamp above
      ClusterA::*> cluster show
      Move epsilon if needed
      ClusterA::*> cluster modify -node nodename -epsilon false
      ClusterA::*> cluster modify -node nodename -epsilon true
      ClusterB::> set advanced -prompt-timestamp above
      ClusterB::*> cluster show
      ClusterB::*> cluster modify -node nodename -epsilon false
      ClusterB::*> cluster modify -node nodename -epsilon true
      ClusterB::*> set admin
  2. Identify and remove the DR group.
    1. Identify the correct DR group for removal:
      metrocluster node show
    2. Remove the DR group nodes:
      metrocluster remove-dr-group -dr-group-id 1
      Note The metrocluster remove-dr-group command is supported only on ONTAP 9.8 and later.
      The following example shows the removal of the DR group configuration on cluster_A.
      Example
      cluster_A::*>
      Warning: Nodes in the DR group that are removed from the MetroCluster
               configuration will lose their disaster recovery protection.
               Local nodes "node_A_1-FC, node_A_2-FC"will be removed from the
               MetroCluster configuration. You must repeat the operation on the
               partner cluster "cluster_B"to remove the remote nodes in the DR group.
      Do you want to continue? {y|n}: y
      Info: The following preparation steps must be completed on the local and partner
            clusters before removing a DR group.
            2. Move all MDV_CRS metadata volumes to another DR group.
            3. Delete all MDV_aud metadata volumes that may exist in the DR group to
            be removed.
            4. Delete all data aggregates in the DR group to be removed. Root
            5. Migrate all data LIFs to home nodes in another DR group.
            6. Migrate the cluster management LIF to a home node in another DR group.
            7. Transfer epsilon to a node in another DR group.
            The command is vetoed if the preparation steps are not completed on the
            local and partner clusters.
      [Job 513] Job succeeded: Remove DR Group is successful.
      cluster_A::*>
  3. Repeat the previous step on the partner cluster.
  4. Disable storage failover on the nodes of the old DR group:
    storage failover modify -node <node-name> -enable false
  5. If you are in a MetroCluster IP configuration, perform the following steps to delete the remote plexes of the root aggregates and remove disk ownership on the nodes of the old DR group.
    In a MetroCluster FC configuration, go to the step for removing the old DR group nodes.
    These steps need to be performed for both nodes in the HA pair at each site.
    1. Display the remote plexes of root aggregates on the nodes in the DR group that is to be deleted:
      storage aggregate plex show -aggregate <root_aggr_name> -pool 1
    2. Delete the remote plexes:
      storage aggregate plex delete -aggregate <root_aggr_name> -plex <plex_from_previous_step>
    3. Identify the remote disks owned by the nodes in the DR group.
      The commands you use depend on whether you are using partitioned/shared disks or whole disks:
      Note Use a comma-separated list in the -owner <node_names> field to specify the node names in the DR group that is to be deleted.
      Partitioned/shared disks:
      1. Set the privilege level to advanced:
      2. Display the remote disks:
        storage disk show -pool Pool1 -owner <node_names> -partition-ownership
      Whole disks:
    4. Disable disk auto assignment:
      disk option modify -node <node_names_in_the_DR_group_to_be_deleted> -autoassign off
    5. Remove ownership of pool1 disks on each DR group node to be deleted. Perform these steps on each node to be removed. In the examples used in this step, node_A_1 is being removed.
      1. Go to the nodeshell:
        run -node <node_name>
      2. Identify the pool1 disks:
        disk show
        All disks are displayed, including the Pool1 disks owned by the node. The following example shows truncated output where disk 0n.4 and its partitions are assigned to Pool1. The output will vary depending on your configuration.
          DISK       OWNER                 POOL   SERIAL NUMBER         HOME                    DR HOME
        0n.4         node_A1(537102267)    Pool1  S3N9NX0J500267        node_A1(537102267)
        0n.4P1       node_A1(537102267)    Pool1  S3N9NX0J500267NP001   node_A1(537102267)
        0n.4P2       node_A1(537102267)    Pool1  S3N9NX0J500267NP002   node_A1(537102267)
        0n.4P3       node_A1(537102267)    Pool1  S3N9NX0J500267NP003   node_A1(537102267)
      3. Set the privilege level to advanced:
        set -privilege advanced -prompt-timestamp above
      4. Remove disk ownership for each pool1 disk:
        If your configuration contains partitioned disks, you first remove ownership of each partitioned disk, and then remove the container disk ownership:
        disk remove_ownership <disk_name>
        In the following example, the ownership of the partitioned disks is removed before the ownership of the container disk 0n.4 is removed:
        *> disk remove_ownership 0n.4P1
        Volumes must be taken offline. Are all impacted volumes offline(y/n)?? y
        Removing the ownership of aggregate disks may lead to partition of aggregates between high-availability pair.
        Do you want to continue(y/n)? y
        *> disk remove_ownership 0n.4P2
        *> disk remove_ownership 0n.4P3
  6. If you are in a MetroCluster IP configuration, remove the MetroCluster connections on the nodes of the old DR group.
    These commands can be issued from either cluster and apply to the entire DR group spanning both of the clusters.
    1. Disconnect the connections:
      metrocluster configuration-settings connection disconnect -dr-group-id <dr_group_id>
      Example
      cluster_A::*> metrocluster configuration-settings connection disconnect -dr-group-id 1
      Warning: For the nodes in the DR group 1, this command will remove the existing connections that are used to mirror NV logs and access remote storage.
      Warning: Before proceeding with disconnect, you must verify the following:
            1. Unmirrored aggregates do not have disks in remote plexes.
            2. Aggregates are not mirrored.
            3. No disks are assigned in Pool1.
            4. Storage failover is not enabled.
            Follow the "MetroCluster Installation and Configuration guide" for detailed instructions to verify this.
    2. Delete the MetroCluster interfaces on the nodes of the old DR group:
      Note This step must be repeated on each node of the DR group.
      metrocluster configuration-settings interface delete
    3. Delete the old DR group's configuration.
      metrocluster configuration-settings dr-group delete
  7. Remove the nodes in the old DR group.
    Perform this step on each cluster.
    1. Set the advanced privilege level:
    2. Remove the node:
      cluster remove-node -node <node-name>
      Repeat this step for the other local node in the old DR group.
    3. Set the admin privilege level:
      set -privilege admin
  8. Check that cluster HA is enabled in the new DR group. If required, re-enable cluster HA:
    cluster ha modify -configured true
  9. Halt, power down, and remove the old controller modules and storage shelves.
Related information
Learn more about the commands used in this procedure in the ONTAP command reference.
