Upgrading or downgrading the firmware on a Brocade FC switch
To upgrade or downgrade the firmware on a Brocade FC switch, you must use the Brocade-specific commands to disable the switch, perform and verify the firmware change, and reboot and reenable the switch.
You must have the firmware files.
The system must be properly cabled.
All paths to the storage shelves must be available.
The disk shelf stacks must be stable.
The FC switch fabric must be healthy.
No failed components can be present in the system.
The system must be operating normally.
You must have the admin password and access to an FTP or SCP server.
The switch fabric is disabled during a firmware upgrade or downgrade, and the MetroCluster configuration relies on the second fabric to continue operation.
This task must be performed on each of the switch fabrics in succession so that all switches are running the same firmware version.
This procedure is nondisruptive and takes approximately one hour to complete. |
Log in to each of the switches in the fabric.
The examples in the following steps use the switch
FC_switch_A_1
Disable each of the switches in the fabric:
switchCfgPersistentDisable
If this command is not available, then run the
switchDisable
command.FC_switch_A_1:admin> switchCfgPersistentDisable
Download the desired firmware version:
firmwareDownload
When prompted for the file name, you must specify the subdirectory or relative path to the firmware file.
You can run the
firmwareDownload
command at the same time on both switches, but you must allow the firmware to download and commit properly before moving to the next step.FC_switch_A_1:admin> firmwaredownload Server Name or IP Address: 10.64.203.188 User Name: test File Name: v7.3.1b Network Protocol(1-auto-select, 2-FTP, 3-SCP, 4-SFTP) [1]: 2 Password: Server IP: 10.64.203.188, Protocol IPv4 Checking system settings for firmwaredownload... System settings check passed.
Verify that the firmware was downloaded and committed to both partitions:
firmwareShow
The following example shows that the firmware download is complete as both images are updated:
FC_switch_A_1:admin> firmwareShow Appl Primary/Secondary Versions ------------------------------------------ FOS v7.3.1b v7.3.1b
Reboot the switches:
reboot
Some firmware versions automatically perform an haReboot operation after the firmware download is finished. The reboot in this step is required even if the haReboot has been performed.
FC_switch_A_1:admin> reboot
Check whether the new firmware is for an intermediate firmware level or for a final specified release.
If the download is for the intermediate firmware level, then perform the previous two steps until the specified release is installed.
Enable the switches:
switchCfgPersistentEnable
If this command is not available, then the switch should be in the
enabled
state after thereboot
command is executed.FC_switch_A_1:admin> switchCfgPersistentEnable
Verify that the switches are online and that all of the devices are properly logged in:
switchShow
FC_switch_A_1:admin> switchShow
Verify that the buffer usage information for a port group or all of the port groups in the switch is displayed properly:
portbuffershow
FC_switch_A_1:admin> portbuffershow
Verify that the current configuration of a port is displayed properly:
portcfgshow
FC_switch_A_1:admin> portcfgshow
Verify the port settings, such as speed, mode, trunking, encryption, and compression, in the Inter-Switch Link (ISL) output. Verify that the port settings were not affected by the firmware download.
Verify the operation of the MetroCluster configuration in ONTAP:
Check whether the system is multipathed:
node run -node node-name sysconfig -a
Check for any health alerts on both clusters:
system health alert show
Confirm the MetroCluster configuration and that the operational mode is normal:
metrocluster show
Perform a MetroCluster check:
metrocluster check run
Display the results of the MetroCluster check:
metrocluster check show
Check for any health alerts on the switches (if present):
storage switch show
Run Config Advisor.
After running Config Advisor, review the tool’s output and follow the recommendations in the output to address any issues discovered.
Wait 15 minutes before repeating this procedure for the second switch fabric.
