Verifying and configuring the HA state of components in Maintenance mode
When configuring a storage system in a MetroCluster configuration, you must make sure that the high-availability (HA) state of the controller module and chassis components is "mcc" or "mcc-2n" so that these components boot properly.
The system must be in Maintenance mode.
This task is not required on systems that are received from the factory.
In Maintenance mode, display the HA state of the controller module and chassis:
ha-config show
The correct HA state depends on your MetroCluster configuration.
Number of controllers in the MetroCluster configuration
HA state for all components should be…
Eight- or four-node MetroCluster FC configuration
mcc
Two-node MetroCluster FC configuration
mcc-2n
MetroCluster IP configuration
mccip
If the displayed system state of the controller is not correct, set the HA state for the controller module:
Command
ha-config modify controller mcc
ha-config modify controller mcc-2n
ha-config modify controller mccip
If the displayed system state of the chassis is not correct, set the HA state for the chassis:
Command
ha-config modify chassis mcc
ha-config modify chassis mcc-2n
ha-config modify chassis mccip
Boot the node to ONTAP:
boot_ontap
Repeat these steps on each node in the MetroCluster configuration.
