ONTAP MetroCluster
Bring an interface port online or offline in a MetroCluster IP configuration
Contributors netapp-aoife netapp-cgoff
When you perform maintenance tasks, you might need to bring a MetroCluster IP interface port offline or online.
About this task
Enable console logging before performing this task.
Steps
You can use the following steps to bring a MetroCluster IP interface port online or take it offline.
  1. Set the privilege level to advanced.
    set -privilege advanced
    Example output
    Cluster A_1::> set -privilege advanced
    Warning: These advanced commands are potentially dangerous; use them only when
             directed to do so by NetApp personnel.
    Do you want to continue? {y|n}: y
  2. Take the MetroCluster IP interface port offline.
    system ha interconnect link off -node <node_name> -link <link_num, 0 or 1>
    Example output
    Cluster_A1::*> system ha interconnect link off -node node-a1 -link 0
    1. Verify the MetroCluster IP interface is offline.
      Cluster_A1::*> system ha interconnect port show
      Example output
                                     Physical  Link
                      Link           Layer     Layer      Physical   Physical  Active
      Node            Monitor  Port  State     State       Link Up  Link Down  Link
      node-a1        off
                                  0  disabled  down              4          3  false
                                  1  linkup    active            4          2  true
      node-a2        off
                                  0  linkup    active            4          2  true
      2 entries were displayed.
  3. Bring the MetroCluster IP interface port online.
    system ha interconnect link on -node <node_name> -link <link_num, 0 or 1>
    Example output
    Cluster_A1::*> system ha interconnect link on -node node-a1 -link 0
    1. Verify the MetroCluster IP interface port is online.
      Example output
                                     Physical  Link
      node-a1        off
                                  0  linkup    active            5          3  true
      node-a2        off
