ONTAP MetroCluster
Setting the HA mode on the existing controller module
Contributors netapp-thomi netapp-ivanad
You must use the storage failover modify command to set the mode on the existing controller module. The mode value is enabled later, after you reboot the controller module.
Steps
  1. Set the mode to HA:
    storage failover modify -mode ha -node existing_node_name
