Example of cabling storage array ports to FC switches in a four-node MetroCluster configuration
PDF of this doc site
Install a fabric-attached MetroCluster
Install a stretch MetroCluster configuration
Transition from MetroCluster FC to MetroCluster IP
Creating your file...
In a MetroCluster configuration with array LUNs, you must connect the storage array ports that form a redundant port pair to alternate FC switches.
The following reference illustration shows the connections between storage arrays and FC switches in a four-node MetroCluster configuration with array LUNs:
If you plan to use disks in addition to array LUNs in your MetroCluster configuration, you must use the switch ports specified for the configuration with disks. |
In the illustration, the redundant array port pairs for both the sites are as follows:
Storage array at Site A:
Ports 1A and 2A
Ports 1B and 2B
Ports 1C and 2C
Ports 1D and 2D
Storage array at Site B:
Ports 1A' and 2A'
Ports 1B' and 2B'
Ports 1C' and 2C'
Ports 1D' and 2D'
FC_switch_A_1 at Site A and FC_switch_B_1 at Site B are connected to form fabric_1. Similarly, FC_switch_A_2 at Site A and FC_switch_B_2 are connected to form fabric_2.
The following table lists the connections between the storage array ports and the FC switches for the MetroCluster illustration:
Array LUN ports |
FC switch ports |
Switch fabrics |
Site A |
1A |
FC_switch_A_1, Port 7 |
fabric_1 |
2A |
FC_switch_A_2, Port 11 |
fabric_2 |
1B |
FC_switch_A_1, Port 8 |
fabric_1 |
2B |
FC_switch_A_2, Port 10 |
fabric_2 |
1C |
FC_switch_A_1, Port 9 |
fabric_1 |
2C |
FC_switch_A_2, Port 9 |
fabric_2 |
1D |
FC_switch_A_1, Port 10 |
fabric_1 |
2D |
FC_switch_A_2, Port 8 |
fabric_2 |
Site B |
1A' |
FC_switch_B_1, Port 7 |
fabric_1 |
2A' |
FC_switch_B_2, Port 11 |
fabric_2 |
1B' |
FC_switch_B_1, Port 8 |
fabric_1 |
2B' |
FC_switch_B_2, Port 10 |
fabric_2 |
1C' |
FC_switch_B_1, Port 9 |
fabric_1 |
2C' |
FC_switch_B_2, Port 9 |
fabric_2 |
1D' |
FC_switch_B_1, Port 10 |
fabric_1 |
2D' |
FC_switch_B_2, Port 8 |
fabric_2 |
