Verify the health of the MetroCluster configuration
You must verify the health and connectivity of the MetroCluster configuration prior to performing the transition
Verify the operation of the MetroCluster configuration in ONTAP:
Check whether the system is multipathed:
node run -node node-name sysconfig -a -
Check for any health alerts on both clusters:
system health alert show -
Confirm the MetroCluster configuration and that the operational mode is normal:
metrocluster show -
Perform a MetroCluster check:
metrocluster check run -
Display the results of the MetroCluster check:
metrocluster check show -
Check for any health alerts on the switches (if present):
storage switch show -
Run Config Advisor.
After running Config Advisor, review the tool's output and follow the recommendations in the output to address any issues discovered.
Verify that the cluster is healthy:
cluster showcluster_A::> cluster show Node Health Eligibility Epsilon -------------- ------ ----------- ------- node_A_1_FC true true false node_A_2_FC true true false cluster_A::>
Verify that all cluster ports are up:
network port show -ipspace clustercluster_A::> network port show -ipspace cluster Node: node_A_1_FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy Node: node_A_2_FC Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0a Cluster Cluster up 9000 auto/10000 healthy e0b Cluster Cluster up 9000 auto/10000 healthy 4 entries were displayed. cluster_A::> -
Verify that all cluster LIFs are up and operational:
network interface show -vserver clusterEach cluster LIF should display "true" for "Is Home" and "up/up" for "Status Admin/Oper".
cluster_A::> network interface show -vserver cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ----- Cluster node_A-1_FC_clus1 up/up 169.254.209.69/16 node_A-1_FC e0a true node_A_1_FC_clus2 up/up 169.254.49.125/16 node_A_1_FC e0b true node_A_2_FC_clus1 up/up 169.254.47.194/16 node_A_2_FC e0a true node_A_2_FC_clus2 up/up 169.254.19.183/16 node_A_2_FC e0b true 4 entries were displayed. cluster_A::> -
Verify that auto-revert is enabled on all cluster LIFs:
network interface show -vserver Cluster -fields auto-revertcluster_A::> network interface show -vserver Cluster -fields auto-revert Logical Vserver Interface Auto-revert --------- ------------- ------------ Cluster node_A_1_FC_clus1 true node_A_1_FC_clus2 true node_A_2_FC_clus1 true node_A_2_FC_clus2 true 4 entries were displayed. cluster_A::>
