ONTAP MetroCluster
Remove ONTAP Mediator or Tiebreaker monitoring before performing maintenance tasks
Contributors netapp-folivia netapp-aoife netapp-sarajane netapp-martyh
Before performing maintenance tasks, you must remove monitoring if the MetroCluster configuration is monitored with the Tiebreaker or Mediator utility.
Maintenance tasks include upgrading the controller platform, upgrading ONTAP, and performing a negotiated switchover and switchback.
Steps
  1. Collect the output for the following command:
    storage iscsi-initiator show
  2. Remove the existing MetroCluster configuration from Tiebreaker, Mediator, or other software that can initiate switchover.
    If you are using…​
    Use this procedure…​
    Tiebreaker
    Removing MetroCluster Configurations in the MetroCluster Tiebreaker Installation and Configuration content
    Mediator
    Issue the following command from the ONTAP prompt:
    metrocluster configuration-settings mediator remove
    Third-party applications
    Refer to the product documentation.
  3. After completing maintenance of the MetroCluster configuration, you can resume monitoring with the Tiebreaker or Mediator utility.
    If you are using…​ Use this procedure
    Tiebreaker
    Adding MetroCluster configurations in the MetroCluster Tiebreaker Installation and Configuration section.
    Mediator
    Configure ONTAP Mediator from a MetroCluster IP configuration in the MetroCluster IP Installation and Configuration section.
