Create a mirrored data aggregate on each MetroCluster FC node
You must create a mirrored data aggregate on each node in the DR group.
You should know what drives will be used in the new aggregate.
If you have multiple drive types in your system (heterogeneous storage), you should understand how you can make sure that the correct drive type is selected.
Drives are owned by a specific node; when you create an aggregate, all drives in that aggregate must be owned by the same node, which becomes the home node for that aggregate.
In systems using ADP, aggregates are created using partitions in which each drive is partitioned in to P1, P2 and P3 partitions.
Aggregate names should conform to the naming scheme you determined when you planned your MetroCluster configuration.
Aggregate names must be unique across the MetroCluster sites. This means that you cannot have two different aggregates with the same name on site A and site B.
It's recommended you maintain at least 20% free space for mirrored aggregates for optimal storage performance and availability. Although the recommendation is 10% for non-mirrored aggregates, the additional 10% of space can be used by the filesystem to absorb incremental changes. Incremental changes increase space utilization for mirrored aggregates due to ONTAP's copy-on-write Snapshot-based architecture. Failure to adhere to these best practices might have a negative impact on performance. |
Display a list of available spares:
storage disk show -spare -owner <node_name> -
Create the aggregate:
storage aggregate create -mirror trueIf you are logged in to the cluster on the cluster management interface, you can create an aggregate on any node in the cluster. To verify that the aggregate is created on a specific node, use the
-nodeparameter or specify drives that are owned by that node.You can specify the following options:
Aggregate's home node (that is, the node that owns the aggregate in normal operation)
List of specific drives that are to be added to the aggregate
Number of drives to include
In the minimum supported configuration, in which a limited number of drives are available, you must use the force-small-aggregate option to allow the creation of a three disk RAID-DP aggregate. -
Checksum style to use for the aggregate
Type of drives to use
Size of drives to use
Drive speed to use
RAID type for RAID groups on the aggregate
Maximum number of drives that can be included in a RAID group
Whether drives with different RPM are allowed
For more information about these options, see the
storage aggregate createman page.The following command creates a mirrored aggregate with 10 disks:
cluster_A::> storage aggregate create aggr1_node_A_1 -diskcount 10 -node node_A_1 -mirror true [Job 15] Job is queued: Create aggr1_node_A_1. [Job 15] The job is starting. [Job 15] Job succeeded: DONE
Verify the RAID group and drives of your new aggregate:
storage aggregate show-status -aggregate <aggregate-name>
