Switch back the MetroCluster IP configuration
Perform the switchback operation to return the MetroCluster configuration to normal operation. The nodes on site_A are still awaiting upgrade.
Issue the
metrocluster node showcommand on site_B and check the output.-
Verify that the new nodes are represented correctly.
Verify that the new nodes are in "Waiting for switchback state."
Perform the healing and switchback by running the required commands from any node in the active cluster (the cluster that is not undergoing upgrade).
Heal the data aggregates:
metrocluster heal aggregates -
Heal the root aggregates:
metrocluster heal root -
Switchback the cluster:
metrocluster switchback
Check the progress of the switchback operation:
metrocluster showThe switchback operation is still in progress when the output displays
waiting-for-switchback:cluster_B::> metrocluster show Cluster Entry Name State ------------------------- ------------------- ----------- Local: cluster_B Configuration state configured Mode switchover AUSO Failure Domain - Remote: cluster_A Configuration state configured Mode waiting-for-switchback AUSO Failure Domain -The switchback operation is complete when the output displays normal:
cluster_B::> metrocluster show Cluster Entry Name State ------------------------- ------------------- ----------- Local: cluster_B Configuration state configured Mode normal AUSO Failure Domain - Remote: cluster_A Configuration state configured Mode normal AUSO Failure Domain -If a switchback takes a long time to finish, you can check on the status of in-progress baselines by using the
metrocluster config-replication resync-status showcommand. This command is at the advanced privilege level.
