Required MetroCluster hardware components and naming conventions for two-node bridge-attached stretch configurations
When planning your MetroCluster configuration, you must understand the required and supported hardware and software components. For convenience and clarity, you should also understand the naming conventions used for components in examples throughout the documentation. For example, one site is referred to as Site A and the other site is referred to as Site B.
Supported software and hardware
The hardware and software must be supported for the MetroCluster FC configuration.
When using AFF systems, all controller modules in the MetroCluster configuration must be configured as AFF systems.
Hardware redundancy in the MetroCluster configuration
Because of the hardware redundancy in the MetroCluster configuration, there are two of each component at each site. The sites are arbitrarily assigned the letters A and B and the individual components are arbitrarily assigned the numbers 1 and 2.
Requirement for two single-node ONTAP clusters
The bridge-attached stretch MetroCluster configuration requires two single-node ONTAP clusters.
Naming must be unique within the MetroCluster configuration.
Example names:
Site A: cluster_A
Site B: cluster_B
Requirement for two storage controller modules
The bridge-attached stretch MetroCluster configuration requires two storage controller modules.
The controllers must meet the following requirements:
All controller modules in the MetroCluster configuration must be running the same version of ONTAP.
All controller modules in a DR group must be of the same model.
All controller modules in a DR group must use the same FC-VI configuration.
Some controller modules support two options for FC-VI connectivity:
Onboard FC-VI ports
An FC-VI card in slot 1
A mix of one controller module using onboard FC-VI ports and another using an add-on FC-VI card is not supported. For example, if one node uses onboard FC-VI configuration, then all other nodes in the DR group must use onboard FC-VI configuration as well.
Example names:
Site A: controller_A_1
Site B: controller_B_1
Requirement for FC-to-SAS bridges
The bridge-attached stretch MetroCluster configuration requires two or more FC-to-SAS bridges at each site.
These bridges connect the SAS disk shelves to the controller modules.
FibreBridge 6500N bridges are not supported in configurations running ONTAP 9.8 and later. |
FibreBridge 7600N and 7500N bridges support up to four SAS stacks.
Each stack can use different models of IOM, but all shelves within a stack must use the same model.
The supported IOM models depend on the ONTAP version you are running.
The suggested names used as examples in this procedure identify the controller module that the bridge connects to and the port.
Example names:
Site A:
bridge_A_1_
port-number -
bridge_A_2_
port-number
Site B:
bridge_B_1_
port-number -
bridge_B_2_
port-number
Requirement for at least four SAS shelves (recommended)
The bridge-attached stretch MetroCluster configuration requires at least two SAS shelves. However, two shelves are recommended at each site to allow disk ownership on a per-shelf basis, for a total of four SAS shelves.
A minimum of one shelf at each site is supported.
Example names:
Site A:
shelf_A_1_1
shelf_A_1_2
Site B:
shelf_B_1_1
shelf_B_1_2
