Switchover, healing, and switchback during MetroCluster transition
Depending on the stage of the transition process, the MetroCluster switchover, healing, and switchback operations use either the MetroCluster FC or MetroCluster IP workflow.
The following table shows what workflows are used at different stages of the transition process. In some stages, switchover and switchback are not supported.
In the MetroCluster FC workflow, the switchover, healing, and switchback steps are those used by a MetroCluster FC configuration.
In the MetroCluster IP workflow, the switchover, healing, and switchback steps are those used by a MetroCluster IP configuration.
In the unified workflow, when both the FC and IP nodes are configured, the steps depend on whether NSO or USO is performed. The details are shown in the table.
For information on the MetroCluster FC and IP workflows for switchover, healing, and switchback, see Understanding MetroCluster data protection and disaster recovery.
Automatic unplanned switchover is not available during the transition process. |
Stage of transition |
Negotiated switchover uses this workflow… |
Unplanned switchover uses this workflow… |
Before the MetroCluster IP nodes have joined the cluster |
MetroCluster FC |
MetroCluster FC |
After the MetroCluster IP nodes have joined the cluster, before the |
Not supported |
MetroCluster FC |
After the |
Unified: All remote site nodes remain up and healing is done automatically |
Unified:
The MetroCluster FC nodes have been unconfigured. |
Not supported |
MetroCluster IP |
The |
MetroCluster IP |
MetroCluster IP |
