ONTAP MetroCluster
MetroCluster FC-to-IP transition procedure options
Contributors netapp-aoife netapp-folivia netapp-aaron-holt netapp-martyh NetAppZacharyWambold netapp-thomi netapp-aherbin
When transitioning to a MetroCluster IP configuration, you must have a combination of supported platform models.
You should also ensure that the MetroCluster IP platform is an appropriate size for the load that you are transitioning from the MetroCluster FC configuration to the MetroCluster IP configuration.
Supported platform combinations
  • The transition procedures all require ONTAP 9.8 or later unless stated otherwise in the notes or as required by an individual platform.
  • All nodes in the MetroCluster configuration must be running the same ONTAP version. For example, if you have an eight-node configuration, all eight nodes must be running the same ONTAP version. Refer to the Hardware universe for the minimum supported ONTAP version for your combination.
Note
  • Do not exceed any object limits of the 'lower' of the platforms in the combination. Apply the lower object limit of the two platforms.
  • If the target platform limits are lower then the MetroCluster limits, you must reconfigure the MetroCluster to be at, or below, the target platform limits before you add the new nodes.
  • Refer to the Hardware universe for platform limits.
Supported AFF and FAS transition combinations
The following tables show the supported platform combinations. You can transition from platforms in the first column to platforms listed as supported in the columns to the right, as indicated by the colored table cells.
For example, transitioning from a MetroCluster FC configuration consisting of AFF8060 controller modules to an IP configuration consisting of AFF A400 controller modules is supported.
The tables are split into two groups:
  • Group 1 shows combinations for transitions to AFF A150, AFF A20, FAS2750, AFF A220, FAS500f, AFF C250, AFF A250, FAS50, AFF C30, AFF A30, FAS8200, AFF A300, AFF A320, FAS8300, AFF C400, AFF A400, and FAS8700 systems.
  • Group 2 shows combinations for transitions to AFF C60, AFF A50, FAS70, FAS9000, AFF A700, AFF A70, AFF C800, AFF A800, FAS9500, AFF A900, AFF C80, FAS90, AFF A90, and AFF A1K systems.
The following notes apply to both groups:
  • Note 1: This platform combination requires ONTAP 9.11.1 or later.
  • Note 2: You must have a 40GbE interface for the local cluster interfaces on the FC nodes.
  • Note 3: You must have a 100GbE interface for the local cluster interfaces on the FC nodes.
AFF and FAS combinations group 1
Review the supported combinations for transitions to AFF A150, AFF A20, FAS2750, AFF A220, FAS500f, AFF C250, AFF A250, FAS50, AFF C30, AFF A30, FAS8200, AFF A300, AFF A320, FAS8300, AFF C400, AFF A400, and FAS8700 systems.
Shows supported transitions for group 1 platforms
AFF and FAS combinations group 2
Review the supported combinations for transitions to AFF C60, AFF A50, FAS70, FAS9000, AFF A700, AFF A70, AFF C800, AFF A800, FAS9500, AFF A900, AFF C80, FAS90, AFF A90, and AFF A1K systems.
Shows supported transitions for group 2 platforms
Supported ASA transition platform combinations
The following table shows the supported platform combinations for ASA systems.
Source MetroCluster FC platform Target MetroCluster IP platform Supported?
ASA A400
ASA A400
Yes
ASA A900
No
ASA A900
ASA A400
No
ASA A900
Yes
Choose your transition procedure
You must select a transition procedure depending on your existing MetroCluster FC configuration.
A transition procedure replaces the back-end FC switch fabric or FC-VI connection with an IP switch network. The exact procedure depends on your starting configuration.
The original platforms and FC switches (if present) are retired at the end of the transition procedure.
Starting configuration
Disruptive or nondisruptive
Requirements
Procedure
Four or eight node
Nondisruptive
New storage shelves are required on new platforms. After the transition is completed, old controllers, shelves and disks are removed from the cluster.
Note: This procedure supports the following FC to IP transitions:
  • From a four-node MetroCluster FC configuration to a four-node MetroCluster IP configuration
  • From an eight-node MetroCluster FC configuration to an eight-node MetroCluster IP configuration
Two node
Disruptive
New storage shelves are supported on both original and new platforms.
Two node
Disruptive
New storage shelves are supported on both original and new platforms. Old storage shelves must be retired.
Two node
Disruptive
Old storage shelves are not supported on new platforms. Old storage shelves must be retired.
