Update the switch RCFs and set the MetroCluster IP bootarg values
Update the switch reference configuration files (RCFs) for the new platforms and set the MetroCluster IP bootarg values on the controller modules.
Update the switch RCFs to accommodate the new platforms
You must update the switches to a configuration that supports the new platform models.
You perform this task at the site containing the controllers that are currently being upgraded. In the examples shown in this procedure we are upgrading site_B first.
The switches at site_A will be upgraded when the controllers on site_A are upgraded.
Prepare the IP switches for the application of the new reference configuration files (RCFs).
Follow the steps in the section for your switch vendor:
Download and install the RCFs.
Set the MetroCluster IP bootarg variables
You must configure certain MetroCluster IP bootarg values on the new controller modules. The bootarg values must match those configured on the old controller modules.
You use the UUIDs and system IDs identified earlier in the upgrade procedure in Gather information before the upgrade.
Depending on your platform model, you can specify the VLAN ID using the
-vlan-idparameter. The following platforms do not support the-vlan-idparameter:-
FAS8200 and AFF A300
AFF A320
FAS9000 and AFF A700
AFF C800, ASA C800, AFF A800, and ASA A800
All other platforms support the
-vlan-idparameter.
The MetroCluster bootarg values you set depend on whether your new system uses shared cluster/HA ports or shared MetroCluster/HA ports.
Shared cluster/HA portsThe systems listed in the following table use shared cluster/HA ports:
AFF and ASA systems FAS systems -
AFF A20
AFF A30
AFF C30
AFF A50
AFF C60
AFF C80
AFF A70
AFF A90
AFF A1K
FAS50
FAS70
FAS90
Shared MetroCluster/HA portsThe systems listed in the following table use shared MetroCluster/HA ports:
AFF A150, ASA A150
AFF A220
AFF C250, ASA C250
AFF A250, ASA A250
AFF A300
AFF A320
AFF C400, ASA C400
AFF A400, ASA A400
AFF A700
AFF C800, ASA C800
AFF A800, ASA A800
AFF A900, ASA A900
FAS2750
FAS500f
FAS8200
FAS8300
FAS8700
FAS9000
FAS9500
At the
LOADER>prompt, set the following bootargs on the new nodes at site_B:The steps you follow depend on the ports used by the new platform model.
Systems that use shared cluster/HA ports-
Set the following bootargs:
setenv bootarg.mcc.port_a_ip_config <local-IP-address/local-IP-mask,0,0,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>setenv bootarg.mcc.port_b_ip_config <local-IP-address/local-IP-mask,0,0,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>If the interfaces are using a default VLAN ID, the vlan-idparameter is not required.The following example sets the values for node_B_1-new using VLAN 120 for the first network and VLAN 130 for the second network:
setenv bootarg.mcc.port_a_ip_config 172.17.26.10/23,0,0,172.17.26.13,172.17.26.12,120 setenv bootarg.mcc.port_b_ip_config 172.17.27.10/23,0,0,172.17.27.13,172.17.27.12,130
The following example sets the values for node_B_2-new using VLAN 120 for the first network and VLAN 130 for the second network:
setenv bootarg.mcc.port_a_ip_config 172.17.26.11/23,0,0,172.17.26.12,172.17.26.13,120 setenv bootarg.mcc.port_b_ip_config 172.17.27.11/23,0,0,172.17.27.12,172.17.27.13,130
The following example sets the values for node_B_1-new using default VLANs for all MetroCluster IP DR connections:
setenv bootarg.mcc.port_a_ip_config 172.17.26.10/23,0,0,172.17.26.13,172.17.26.12 setenv bootarg.mcc.port_b_ip_config 172.17.27.10/23,0,0,172.17.27.13,172.17.27.12
The following example sets the values for node_B_2-new using default VLANs for all MetroCluster IP DR connections:
setenv bootarg.mcc.port_a_ip_config 172.17.26.11/23,0,0,172.17.26.12,172.17.26.13 setenv bootarg.mcc.port_b_ip_config 172.17.27.11/23,0,0,172.17.27.12,172.17.27.13
Systems that use shared MetroCluster/HA ports-
setenv bootarg.mcc.port_a_ip_config <local-IP-address/local-IP-mask,0,HA-partner-IP-address,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>setenv bootarg.mcc.port_b_ip_config <local-IP-address/local-IP-mask,0,HA-partner-IP-address,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>If the interfaces are using a default VLAN ID, the vlan-idparameter is not required.The following example sets the values for node_B_1-new using VLAN 120 for the first network and VLAN 130 for the second network:
setenv bootarg.mcc.port_a_ip_config 172.17.26.10/23,0,172.17.26.11,172.17.26.13,172.17.26.12,120 setenv bootarg.mcc.port_b_ip_config 172.17.27.10/23,0,172.17.27.11,172.17.27.13,172.17.27.12,130
setenv bootarg.mcc.port_a_ip_config 172.17.26.11/23,0,172.17.26.10,172.17.26.12,172.17.26.13,120 setenv bootarg.mcc.port_b_ip_config 172.17.27.11/23,0,172.17.27.10,172.17.27.12,172.17.27.13,130
setenv bootarg.mcc.port_a_ip_config 172.17.26.10/23,0,172.17.26.11,172.17.26.13,172.17.26.12 setenv bootarg.mcc.port_b_ip_config 172.17.27.10/23,0,172.17.27.11,172.17.27.13,172.17.27.12
setenv bootarg.mcc.port_a_ip_config 172.17.26.11/23,0,172.17.26.10,172.17.26.12,172.17.26.13 setenv bootarg.mcc.port_b_ip_config 172.17.27.11/23,0,172.17.27.10,172.17.27.12,172.17.27.13
At the new nodes' LOADER prompt, set the UUIDs:
setenv bootarg.mgwd.partner_cluster_uuid <partner-cluster-UUID>setenv bootarg.mgwd.cluster_uuid <local-cluster-UUID>setenv bootarg.mcc.pri_partner_uuid <DR-partner-node-UUID>setenv bootarg.mcc.aux_partner_uuid <DR-aux-partner-node-UUID>setenv bootarg.mcc_iscsi.node_uuid <local-node-UUID>-
Set the UUIDs on node_B_1-new:
The following example shows the commands for setting the UUIDs on node_B_1-new:
setenv bootarg.mgwd.cluster_uuid ee7db9d5-9a82-11e7-b68b-00a098908039 setenv bootarg.mgwd.partner_cluster_uuid 07958819-9ac6-11e7-9b42-00a098c9e55d setenv bootarg.mcc.pri_partner_uuid f37b240b-9ac1-11e7-9b42-00a098c9e55d setenv bootarg.mcc.aux_partner_uuid bf8e3f8f-9ac4-11e7-bd4e-00a098ca379f setenv bootarg.mcc_iscsi.node_uuid f03cb63c-9a7e-11e7-b68b-00a098908039
Set the UUIDs on node_B_2-new:
The following example shows the commands for setting the UUIDs on node_B_2-new:
setenv bootarg.mgwd.cluster_uuid ee7db9d5-9a82-11e7-b68b-00a098908039 setenv bootarg.mgwd.partner_cluster_uuid 07958819-9ac6-11e7-9b42-00a098c9e55d setenv bootarg.mcc.pri_partner_uuid bf8e3f8f-9ac4-11e7-bd4e-00a098ca379f setenv bootarg.mcc.aux_partner_uuid f37b240b-9ac1-11e7-9b42-00a098c9e55d setenv bootarg.mcc_iscsi.node_uuid aa9a7a7a-9a81-11e7-a4e9-00a098908c35
Determine whether the original systems were configured for Advanced Drive Partitioning (ADP) by running the following command from the site that is up:
disk showThe "container type" column displays "shared" in the
disk showoutput if ADP is configured. If "container type" has any other value, ADP is not configured on the system. The following example output shows a system configured with ADP:::> disk show Usable Disk Container Container Disk Size Shelf Bay Type Type Name Owner Info: This cluster has partitioned disks. To get a complete list of spare disk capacity use "storage aggregate show-spare-disks". ---------------- ---------- ----- --- ------- ----------- --------- -------- 1.11.0 894.0GB 11 0 SSD shared testaggr node_A_1 1.11.1 894.0GB 11 1 SSD shared testaggr node_A_1 1.11.2 894.0GB 11 2 SSD shared testaggr node_A_1 -
If the original systems were configured with partitioned disks for ADP, enable it at the
LOADERprompt for each replacement node:setenv bootarg.mcc.adp_enabled true -
Set the following variables:
setenv bootarg.mcc.local_config_id <original-sys-id>setenv bootarg.mcc.dr_partner <dr-partner-sys-id>The setenv bootarg.mcc.local_config_idvariable must be set to the sys-id of the original controller module, node_B_1-old.-
Set the variables on node_B_1-new.
The following example shows the commands for setting the values on node_B_1-new:
setenv bootarg.mcc.local_config_id 537403322 setenv bootarg.mcc.dr_partner 537403324
Set the variables on node_B_2-new.
The following example shows the commands for setting the values on node_B_2-new:
setenv bootarg.mcc.local_config_id 537403321 setenv bootarg.mcc.dr_partner 537403323
If using encryption with external key manager, set the required bootargs:
setenv bootarg.kmip.init.ipaddrsetenv bootarg.kmip.kmip.init.netmasksetenv bootarg.kmip.kmip.init.gatewaysetenv bootarg.kmip.kmip.init.interface
