Checking for MetroCluster configuration errors with Config Advisor
You can go to the NetApp Support Site and download the Config Advisor tool to check for common configuration errors.
About this task
Config Advisor is a configuration validation and health check tool. You can deploy it at both secure sites and non-secure sites for data collection and system analysis.
Support for Config Advisor is limited, and available only online. |
Steps
Go to the Config Advisor download page and download the tool.
Run Config Advisor, review the tool's output and follow the recommendations in the output to address any issues discovered.
