wafl_comp_aggr_vol_bin
CM object for exporting Composit Aggregate bin volume statistics.
Classic Object: wafl_comp_aggr_vol_bin
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
System node name |
comp_aggr_name |
aggregate.name |
Name of the Composite Aggregate. |
vserver_name |
svm.name |
Name of the SVM that owns this volume |
vserver_uuid |
svm.uuid |
UUID for the SVM that owns this volume |
vol_name |
volume.name |
Name of the FlexVol volume. |
vol_uuid |
volume.uuid |
UUID of the FlexVol volume. |
bin_uuid |
bin.uuid |
UUID of this bin. |
object_store_name |
cloud_target.name |
Name of the object store configuration |
object_store_uuid |
cloud_target.uuid |
UUID of the object store configuration. |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
bin_id |
bin.id |
Bin ID (0..7) |
config_id |
config_id |
Config ID of the object store |
cloud_bin_space |
cloud_bin_space |
Cloud bin capacity counters. |
cloud_bin_operation |
cloud_bin_op |
Cloud bin operation counters. |
cloud_bin_op_size |
cloud_bin_op_size |
Cloud bin operation sizes in bytes. |
cloud_bin_op_latency_average |
Cloud bin operation latency average in milliseconds. |
bin_error_io_timedout |
error_io_timedout |
Number of cloud I/Os that are timed out. |
bin_tlog_reads |
transfer_log_reads |
Total reads from transfer log. |
bin_reads |
reads |
Total number of blocks read. |
bin_ra_reads |
readahead_reads |
Total number of blocks read via readahead. |
bin_client_proto_reads |
client_protocol_reads |
Total number of blocks read via client protocols. |
bin_repl_proto_reads |
replication_protocol_reads |
Total number of blocks read via replication protocol. |
bin_other_proto_reads |
other_protocol_reads |
Total number of blocks read via other protocols. |
bin_read_requests |
read_requests |
Total number of cloud IO read requests. |
bin_client_read_requests |
Total number of cloud IO read requests via client protocols. |
bin_error_op_expired_before_io |
error_operations_expired_before_io |
Number of operations expired before cloud I/Os are issued. |
bin_error_op_soon_expire_before_io |
error_operations_soon_expire_before_io |
Number of operations that will expire before cloud I/Os are issued. |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
cloud_bin_op |
Two things were changed about the naming of these array labels: |
cloud_bin_op_size |
Table Aliases
This section describes aliases for aggregated tables.
