ONTAP 9.13.1 performance counter mapping
wafl_comp_aggr_vol_bin
CM object for exporting Composit Aggregate bin volume statistics.
Classic Object: wafl_comp_aggr_vol_bin
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
comp_aggr_name
aggregate.name
Name of the Composite Aggregate.
vserver_name
svm.name
Name of the SVM that owns this volume
vserver_uuid
svm.uuid
UUID for the SVM that owns this volume
vol_name
volume.name
Name of the FlexVol volume.
vol_uuid
volume.uuid
UUID of the FlexVol volume.
bin_uuid
bin.uuid
UUID of this bin.
object_store_name
cloud_target.name
Name of the object store configuration
object_store_uuid
cloud_target.uuid
UUID of the object store configuration.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
bin_id
bin.id
Bin ID (0..7)
config_id
config_id
Config ID of the object store
cloud_bin_space
cloud_bin_space
Cloud bin capacity counters.
cloud_bin_operation
cloud_bin_op
Cloud bin operation counters.
cloud_bin_op_size
cloud_bin_op_size
Cloud bin operation sizes in bytes.
cloud_bin_op_latency_average
Cloud bin operation latency average in milliseconds.
bin_error_io_timedout
error_io_timedout
Number of cloud I/Os that are timed out.
bin_tlog_reads
transfer_log_reads
Total reads from transfer log.
bin_reads
reads
Total number of blocks read.
bin_ra_reads
readahead_reads
Total number of blocks read via readahead.
bin_client_proto_reads
client_protocol_reads
Total number of blocks read via client protocols.
bin_repl_proto_reads
replication_protocol_reads
Total number of blocks read via replication protocol.
bin_other_proto_reads
other_protocol_reads
Total number of blocks read via other protocols.
bin_read_requests
read_requests
Total number of cloud IO read requests.
bin_client_read_requests
Total number of cloud IO read requests via client protocols.
bin_error_op_expired_before_io
error_operations_expired_before_io
Number of operations expired before cloud I/Os are issued.
bin_error_op_soon_expire_before_io
error_operations_soon_expire_before_io
Number of operations that will expire before cloud I/Os are issued.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
cloud_bin_op
Two things were changed about the naming of these array labels:
1. All of the spaces and hyphens were converted to underscores.
2. All of the letters were converted to lowercase.
cloud_bin_op_size
Table Aliases
This section describes aliases for aggregated tables.
