wafl_comp_aggr_bin
CM object for exporting Composite Aggregate bin statistics.
Classic Object: wafl_comp_aggr_bin
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
System node name |
comp_aggr_name |
aggregate.name |
Name of the Composite Aggregate. |
bin_uuid |
bin.uuid |
UUID of this bin. |
object_store_name |
cloud_target.name |
Name of the object store configuration |
object_store_uuid |
cloud_target.uuid |
UUID of the object store configuration. |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
bin_id |
bin.id |
Bin ID (0..7) |
config_id |
config_id |
Config ID of the object store |
cloud_bin_operation |
cloud_bin_op |
Cloud bin operation counters. |
cloud_bin_op_size |
cloud_bin_op_size |
Cloud bin operation size counters in bytes. |
cloud_bin_op_latency_average |
Cloud bin operation latency average in milliseconds. |
cloud_bin_op_latency_histogram |
Cloud bin operation latency histogram in milliseconds. |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
cloud_bin_op |
All of the letters were converted to lowercase while changing the |
cloud_bin_op_size |
Table Aliases
This section describes aliases for aggregated tables.
