ONTAP 9.14.1 performance counter mapping
wafl_comp_aggr_bin
CM object for exporting Composite Aggregate bin statistics.
Classic Object: wafl_comp_aggr_bin
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
comp_aggr_name
aggregate.name
Name of the Composite Aggregate.
bin_uuid
bin.uuid
UUID of this bin.
object_store_name
cloud_target.name
Name of the object store configuration
object_store_uuid
cloud_target.uuid
UUID of the object store configuration.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
bin_id
bin.id
Bin ID (0..7)
config_id
config_id
Config ID of the object store
cloud_bin_operation
cloud_bin_op
Cloud bin operation counters.
cloud_bin_op_size
cloud_bin_op_size
Cloud bin operation size counters in bytes.
cloud_bin_op_latency_average
Cloud bin operation latency average in milliseconds.
cloud_bin_op_latency_histogram
Cloud bin operation latency histogram in milliseconds.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
cloud_bin_op
All of the letters were converted to lowercase while changing the
naming of these array labels.
cloud_bin_op_size
  1. All of the letters were converted to lowercase while changing the
  2. The labels have changed from "0 - <1ms" to "0-<1ms".
Table Aliases
This section describes aliases for aggregated tables.
