ONTAP performance counter mapping
nfs_v4_diag
The NFSv4_diag object reports low-level diagnostics for the Network File System protocol, version 4. This is the ISOC file-sharing protocol that is predominant on UNIX platforms, used to connect to Network Attached Storage (NAS).
Classic Object: nfsv4_diag
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Name of the node.
instance_name
name
Name of the row.
instance_uuid
uuid
Unique identifier (UUID) for the object.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
storePool_ClientMax
storepool.client_maximum
Maximum number of client objects.
storePool_ClientAlloc
storepool.client_allocated
Current number of client objects allocated.
storePool_SessionMax
storepool.session_maximum
Maximum number of session objects.
storePool_SessionAlloc
storepool.session_allocated
Current number of session objects allocated.
storePool_SessionHolderMax
storepool.session_holder_maximum
Maximum number of session holder objects.
storePool_SessionHolderAlloc
storepool.session_holder_allocated
Current number of session holder objects allocated.
storePool_SessionConnectionHolderAlloc
storepool.session_connection_holder_allocated
Current number of session connection holder objects allocated.
storePool_SessionConnectionHolderMax
storepool.session_connection_holder_maximum
Maximum number of session connection holder objects.
storePool_ConnectionParentSessionReferenceAlloc
storepool.connection_parent_session_reference_allocated
Current number of connection parent session reference objects allocated.
storePool_ConnectionParentSessionReferenceMax
storepool.connection_parent_session_reference_maximum
Maximum number of connection parent session reference objects.
storePool_StringMax
storepool.string_maximum
Maximum number of string objects.
storePool_StringAlloc
storepool.string_allocated
Current number of string objects allocated.
storePool_OwnerMax
storepool.owner_maximum
Maximum number of owner objects.
storePool_OwnerAlloc
storepool.owner_allocated
Current number of owner objects allocated.
storePool_OpenStateMax
storepool.openstate_maximum
Maximum number of open state objects.
storePool_OpenStateAlloc
storepool.openstate_allocated
Current number of open state objects allocated.
storePool_DelegStateMax
storepool.delegation_state_maximum
Maximum number of delegation state objects.
storePool_DelegStateAlloc
storepool.delegation_state_allocated
Current number of delegation state objects allocated.
storePool_LockStateMax
storepool.lock_state_maximum
Maximum number of lock state objects.
storePool_LockStateAlloc
storepool.lock_state_allocated
Current number of lock state objects allocated.
storePool_LayoutStateMax
storepool.layout_state_maximum
Maximum number of layout state objects.
storePool_LayoutStateAlloc
storepool.layout_state_allocated
Current number of layout state objects allocated.
storePool_CopyStateMax
storepool.copy_state_maximum
Maximum number of copy state objects.
storePool_CopyStateAlloc
storepool.copy_state_allocated
Current number of copy state objects allocated.
storePool_OpenMax
storepool.open_maximum
Maximum number of share lock objects.
storePool_OpenAlloc
storepool.open_allocated
Current number of share objects allocated.
storePool_DelegMax
storepool.delegation_maximum
Maximum number delegation lock objects.
storePool_DelegAlloc
storepool.delegation_allocated
Current number of delegation lock objects allocated.
storePool_LayoutMax
storepool.layout_maximum
Maximum number of layout objects.
storePool_LayoutAlloc
storepool.layout_allocated
Current number of layout objects allocated.
storepool_lock_layout_max
storepool.lock_layout_maximum
Maximum number of layout lock objects.
storepool_lock_layout_alloc
storepool.lock_layout_allocated
Current number of layout lock objects allocated.
storePool_ByteLockMax
storepool.byte_lock_maximum
Maximum number of byte range lock objects.
storePool_ByteLockAlloc
storepool.byte_lock_allocated
Current number of byte range lock objects allocated.
storePool_StateRefHistoryMax
storepool.state_reference_history_maximum
Maximum number of state reference callstack history objects.
storePool_StateRefHistoryAlloc
storepool.state_reference_history_allocated
Current number of state reference callstack history objects allocated.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
