nfs_v4_diag
The NFSv4_diag object reports low-level diagnostics for the Network File System protocol, version 4. This is the ISOC file-sharing protocol that is predominant on UNIX platforms, used to connect to Network Attached Storage (NAS).
Classic Object: nfsv4_diag
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name}:{instance_uuid} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
Name of the node. |
instance_name |
name |
Name of the row. |
instance_uuid |
uuid |
Unique identifier (UUID) for the object. |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
storePool_ClientMax |
storepool.client_maximum |
Maximum number of client objects. |
storePool_ClientAlloc |
storepool.client_allocated |
Current number of client objects allocated. |
storePool_SessionMax |
storepool.session_maximum |
Maximum number of session objects. |
storePool_SessionAlloc |
storepool.session_allocated |
Current number of session objects allocated. |
storePool_SessionHolderMax |
storepool.session_holder_maximum |
Maximum number of session holder objects. |
storePool_SessionHolderAlloc |
storepool.session_holder_allocated |
Current number of session holder objects allocated. |
storePool_SessionConnectionHolderAlloc |
storepool.session_connection_holder_allocated |
Current number of session connection holder objects allocated. |
storePool_SessionConnectionHolderMax |
storepool.session_connection_holder_maximum |
Maximum number of session connection holder objects. |
storePool_ConnectionParentSessionReferenceAlloc |
storepool.connection_parent_session_reference_allocated |
Current number of connection parent session reference objects allocated. |
storePool_ConnectionParentSessionReferenceMax |
storepool.connection_parent_session_reference_maximum |
Maximum number of connection parent session reference objects. |
storePool_StringMax |
storepool.string_maximum |
Maximum number of string objects. |
storePool_StringAlloc |
storepool.string_allocated |
Current number of string objects allocated. |
storePool_OwnerMax |
storepool.owner_maximum |
Maximum number of owner objects. |
storePool_OwnerAlloc |
storepool.owner_allocated |
Current number of owner objects allocated. |
storePool_OpenStateMax |
storepool.openstate_maximum |
Maximum number of open state objects. |
storePool_OpenStateAlloc |
storepool.openstate_allocated |
Current number of open state objects allocated. |
storePool_DelegStateMax |
storepool.delegation_state_maximum |
Maximum number of delegation state objects. |
storePool_DelegStateAlloc |
storepool.delegation_state_allocated |
Current number of delegation state objects allocated. |
storePool_LockStateMax |
storepool.lock_state_maximum |
Maximum number of lock state objects. |
storePool_LockStateAlloc |
storepool.lock_state_allocated |
Current number of lock state objects allocated. |
storePool_LayoutStateMax |
storepool.layout_state_maximum |
Maximum number of layout state objects. |
storePool_LayoutStateAlloc |
storepool.layout_state_allocated |
Current number of layout state objects allocated. |
storePool_CopyStateMax |
storepool.copy_state_maximum |
Maximum number of copy state objects. |
storePool_CopyStateAlloc |
storepool.copy_state_allocated |
Current number of copy state objects allocated. |
storePool_OpenMax |
storepool.open_maximum |
Maximum number of share lock objects. |
storePool_OpenAlloc |
storepool.open_allocated |
Current number of share objects allocated. |
storePool_DelegMax |
storepool.delegation_maximum |
Maximum number delegation lock objects. |
storePool_DelegAlloc |
storepool.delegation_allocated |
Current number of delegation lock objects allocated. |
storePool_LayoutMax |
storepool.layout_maximum |
Maximum number of layout objects. |
storePool_LayoutAlloc |
storepool.layout_allocated |
Current number of layout objects allocated. |
storepool_lock_layout_max |
storepool.lock_layout_maximum |
Maximum number of layout lock objects. |
storepool_lock_layout_alloc |
storepool.lock_layout_allocated |
Current number of layout lock objects allocated. |
storePool_ByteLockMax |
storepool.byte_lock_maximum |
Maximum number of byte range lock objects. |
storePool_ByteLockAlloc |
storepool.byte_lock_allocated |
Current number of byte range lock objects allocated. |
storePool_StateRefHistoryMax |
storepool.state_reference_history_maximum |
Maximum number of state reference callstack history objects. |
storePool_StateRefHistoryAlloc |
storepool.state_reference_history_allocated |
Current number of state reference callstack history objects allocated. |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
