nvmf_rdma_port
An NVMF RDMA port is a logical interface that connects a SVM to a physical RoCE-V2 capable device. This table collects diagnostics and performance information for an NVMe/RDMA port. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric on a LIF. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric at a LIF level granularity. The alias names for nvmf_rdma_port:port and nvmf_rdma_port:node are nvmf_rdma_port_port and nvmf_rdma_port_node.
Classic Object: nvmf_rdma_port
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name}:{instance_uuid} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
{node.name}:{instance_name}:{instance_uuid} |
constituent |
This represents the construction of a row ID field for a row from a single node. |
{port.id}:{port_ip_addr} |
port |
This represents the construction of the row ID field in port combo object, which is a single unique string that identifies a row. |
{node.name}:{node.uuid} |
node |
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
Name of the node hosting the RDMA logical interface. |
node_uuid |
node.uuid |
UUID of the node hosting the RDMA logical interface |
instance_name |
name |
Name of the row. |
instance_uuid |
uuid |
Unique identifier (UUID) for the row. |
vserver_name |
svm.name |
Name of the SVM that owns this logical interface (LIF) |
vserver_uuid |
svm.uuid |
UUID of the SVM that owns this logical interface (LIF) |
port_ip_addr |
port_ip_addr |
IP address for the port |
port.id |
port.id |
ID for the port |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
read_ops |
read_ops |
Number of read operations |
write_ops |
write_ops |
Number of write operations |
other_ops |
other_ops |
Number of operations that are not read, write, compare or compare-and-right. |
total_ops |
total_ops |
Total number of operations. |
read_data |
read_data |
Amount of data read from the storage system |
write_data |
write_data |
Amount of data written to the storage system |
total_data |
total_data |
Amount of NVMF traffic to and from the storage system |
avg_read_latency |
average_read_latency |
Average latency for read operations |
avg_write_latency |
average_write_latency |
Average latency for write operations |
avg_other_latency |
average_other_latency |
Average latency for operations other than read, write, compare or compare-and- |
avg_latency |
average_latency |
Average latency for NVMF operations |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
| Classic Object | Alias |
nvmf_rdma_port:port |
nvmf_rdma_port_port |
nvmf_rdma_port:node |
nvmf_rdma_port_node |
