ONTAP performance counter mapping
nvmf_rdma_port
An NVMF RDMA port is a logical interface that connects a SVM to a physical RoCE-V2 capable device. This table collects diagnostics and performance information for an NVMe/RDMA port. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric on a LIF. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric at a LIF level granularity. The alias names for nvmf_rdma_port:port and nvmf_rdma_port:node are nvmf_rdma_port_port and nvmf_rdma_port_node.
Classic Object: nvmf_rdma_port
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
{port.id}:{port_ip_addr}
port
This represents the construction of the row ID field in port combo object, which is a single unique string that identifies a row.
{node.name}:{node.uuid}
node
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Name of the node hosting the RDMA logical interface.
node_uuid
node.uuid
UUID of the node hosting the RDMA logical interface
instance_name
name
Name of the row.
instance_uuid
uuid
Unique identifier (UUID) for the row.
vserver_name
svm.name
Name of the SVM that owns this logical interface (LIF)
vserver_uuid
svm.uuid
UUID of the SVM that owns this logical interface (LIF)
port_ip_addr
port_ip_addr
IP address for the port
port.id
port.id
ID for the port
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
read_ops
read_ops
Number of read operations
write_ops
write_ops
Number of write operations
other_ops
other_ops
Number of operations that are not read, write, compare or compare-and-right.
total_ops
total_ops
Total number of operations.
read_data
read_data
Amount of data read from the storage system
write_data
write_data
Amount of data written to the storage system
total_data
total_data
Amount of NVMF traffic to and from the storage system
avg_read_latency
average_read_latency
Average latency for read operations
avg_write_latency
average_write_latency
Average latency for write operations
avg_other_latency
average_other_latency
Average latency for operations other than read, write, compare or compare-and-
write
avg_latency
average_latency
Average latency for NVMF operations
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
Classic Object Alias
nvmf_rdma_port:port
nvmf_rdma_port_port
nvmf_rdma_port:node
nvmf_rdma_port_node
