ONTAP performance counter mapping
qos_volume
The workload_volume table provides workload statistics on a per volume basis. Workload information at a file or LUN level are not shown by this table (See the workload table). This table provides information such as operations per second, a breakdown of where read operations are going, the interarrival time of operation request messages, working set size information, operation latency per workload, and deferred workload information.
Classic Object: workload_volume
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
instance_name
name
This is the name of the constituent workload row.
instance_uuid
uuid
This is the unique identifier for the qos_volume row. While the qos_volume name
may change, the UUID will not change.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
latency
latency
This is the average response time for requests that were initiated by the
workload.
ops
ops
This field is the workload's rate of operations that completed during the
measurement interval; measured per second.
read_data
read_data
This is the amount of data read per second from the filer by the workload.
read_io_type
read_io_type_percent
This is the percentage of read requests served from various components (such as
buffer cache, ext_cache, disk, etc.).
read_io_type_base
read_io_type_base
This is the total number of WAFL read requests. It is used as a base counter (or
denominator) for the read_io_types counter, to compute the percentage of reads
by various WAFL components.
read_latency
read_latency
This is the average response time for read requests that were initiated by the
workload.
read_ops
read_ops
This is the rate of this workload's read operations that completed during the
measurement interval.
sequential_reads
sequential_reads_percent
This is the percentage of reads, performed on behalf of the workload, that were
sequential.
sequential_reads_base
This is the total number of reads, performed on behalf of the workload. It is
used as a base counter (or denominator) for the sequential_reads_percent counter
to compute the percentage of sequential reads.
sequential_writes_percent
This is the percentage of writes, performed on behalf of the workload, that were
sequential. This counter is only available on platforms with more than 4GB of
NVRAM.
sequential_writes_base
This is the total number of writes, performed on behalf of the workload. This is
used as a base counter (or denominator) for the sequential_writes_percent
counter to compute the percentage of sequential writes.
total_data
total_data
This is the total amount of data read/written per second from/to the filer by
the workload.
write_data
write_data
This is the amount of data written per second to the filer by the workload.
write_latency
write_latency
This is the average response time for write requests that were initiated by the
workload.
write_ops
write_ops
This is the workload's write operations that completed during the measurement
concurrency
concurrency
This is the average number of concurrent requests for the workload.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
