qos_volume
The workload_volume table provides workload statistics on a per volume basis. Workload information at a file or LUN level are not shown by this table (See the workload table). This table provides information such as operations per second, a breakdown of where read operations are going, the interarrival time of operation request messages, working set size information, operation latency per workload, and deferred workload information.
Classic Object: workload_volume
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name}:{instance_uuid} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
{node.name}:{instance_name}:{instance_uuid} |
constituent |
This represents the construction of a row ID field for a row from a single node. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
System node name |
instance_name |
name |
This is the name of the constituent workload row. |
instance_uuid |
uuid |
This is the unique identifier for the qos_volume row. While the qos_volume name |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
latency |
latency |
This is the average response time for requests that were initiated by the |
ops |
ops |
This field is the workload's rate of operations that completed during the |
read_data |
read_data |
This is the amount of data read per second from the filer by the workload. |
read_io_type |
read_io_type_percent |
This is the percentage of read requests served from various components (such as |
read_io_type_base |
read_io_type_base |
This is the total number of WAFL read requests. It is used as a base counter (or |
read_latency |
read_latency |
This is the average response time for read requests that were initiated by the |
read_ops |
read_ops |
This is the rate of this workload's read operations that completed during the |
sequential_reads |
sequential_reads_percent |
This is the percentage of reads, performed on behalf of the workload, that were |
sequential_reads_base |
This is the total number of reads, performed on behalf of the workload. It is |
sequential_writes_percent |
This is the percentage of writes, performed on behalf of the workload, that were |
sequential_writes_base |
This is the total number of writes, performed on behalf of the workload. This is |
total_data |
total_data |
This is the total amount of data read/written per second from/to the filer by |
write_data |
write_data |
This is the amount of data written per second to the filer by the workload. |
write_latency |
write_latency |
This is the average response time for write requests that were initiated by the |
write_ops |
write_ops |
This is the workload's write operations that completed during the measurement |
concurrency |
concurrency |
This is the average number of concurrent requests for the workload. |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
