ONTAP performance counter mapping
svm_vscan
Counter Manager (CM) table for exporting per Vserver Offbox Vscan counters. These counters provide the overall health of the Vscan feature.
Classic Object: offbox_vscan
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
instance_name
name
Constituent SVM name
vserver_id
svm.id
Vserver ID
svm.name
svm.name
Vserver Name
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
dispatch_latency_base
dispatch.requests
Total number of requests to be used as a base counter for average dispatch
latency calculation
dispatch_latency
dispatch.latency
Average dispatch latency
scan_latency_base
scan.requests
Total number of requests to be used as a base counter for average scan latency
calculation
scan_latency
scan.latency
Average scan latency
scan_noti_received_rate
scan.notification_received_rate
Total number of scan notifications received by the dispatcher per second
scan_request_dispatched_rate
scan.request_dispatched_rate
Total number of scan requests sent to the Vscanner per second
connections_active
connections_active
Total number of current active connections
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
