svm_vscan
Counter Manager (CM) table for exporting per Vserver Offbox Vscan counters. These counters provide the overall health of the Vscan feature.
Classic Object: offbox_vscan
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name}:{instance_uuid} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
{node.name}:{instance_name}:{instance_uuid} |
constituent |
This represents the construction of a row ID field for a row from a single node. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
System node name |
instance_name |
name |
Constituent SVM name |
vserver_id |
svm.id |
Vserver ID |
svm.name |
svm.name |
Vserver Name |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
dispatch_latency_base |
dispatch.requests |
Total number of requests to be used as a base counter for average dispatch |
dispatch_latency |
dispatch.latency |
Average dispatch latency |
scan_latency_base |
scan.requests |
Total number of requests to be used as a base counter for average scan latency |
scan_latency |
scan.latency |
Average scan latency |
scan_noti_received_rate |
scan.notification_received_rate |
Total number of scan notifications received by the dispatcher per second |
scan_request_dispatched_rate |
scan.request_dispatched_rate |
Total number of scan requests sent to the Vscanner per second |
connections_active |
Total number of current active connections |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
