rewind_context
These counters are used to monitor the performance of the rewind context manager in the nblade.
Classic Object: rw_ctx
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
Node Name. |
node_uuid |
node.uuid |
Node UUID. |
instance_name |
name |
Name of the rewind context. |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
nfs_rewinds |
nfs_rewinds |
Array of number of rewinds for NFS ops based on their reasons. |
nfs_giveups |
nfs_give_ups |
Array of number of give-ups of NFS ops because they rewind more than a certain |
cifs_rewinds |
cifs_rewinds |
Array of number of rewinds for CIFS ops based on their reasons. |
cifs_giveups |
cifs_give_ups |
Array of number of give-ups of CIFS ops because they rewind more than a certain |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
nfs_rewinds |
Most array labels are kept the same. In general, labels containing abbreviations are expanded. |
nfs_give_ups |
cifs_rewinds |
cifs_give_ups |
Table Aliases
This section describes aliases for aggregated tables.
