ONTAP performance counter mapping
rewind_context
These counters are used to monitor the performance of the rewind context manager in the nblade.
Classic Object: rw_ctx
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Node Name.
node_uuid
node.uuid
Node UUID.
instance_name
name
Name of the rewind context.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
nfs_rewinds
nfs_rewinds
Array of number of rewinds for NFS ops based on their reasons.
nfs_giveups
nfs_give_ups
Array of number of give-ups of NFS ops because they rewind more than a certain
threshold, categorized by their rewind reasons.
cifs_rewinds
cifs_rewinds
Array of number of rewinds for CIFS ops based on their reasons.
cifs_giveups
cifs_give_ups
Array of number of give-ups of CIFS ops because they rewind more than a certain
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
nfs_rewinds
Most array labels are kept the same. In general, labels containing abbreviations are expanded.
Two specific labels that are changed more than the general change are
1. "FC Close DOC" is changed to "FlexCache Deletion On Last Close".
2. "Dpo msg failed" is changed to "Insufficient Memory for RPC-over-RDMA Buffer Allocation".
nfs_give_ups
cifs_rewinds
cifs_give_ups
Table Aliases
This section describes aliases for aggregated tables.
