REST API reference
Delete a license
Removes a license from the ONTAP system, which is typically done when a license is no longer needed or needs to be replaced.
HTTP method and endpoint
DELETE /cluster/licensing/licenses/{name}
Introduced in
ONTAP 9.6
Usage notes
Deletes a license.
  • system license delete
name
string
path
True
Name of the license package to delete.
serial_number
string
query
True
Serial number of the license to delete.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
525028
Error during volume limit check, cannot remove license
525029
Current volume use will exceed limits if license is removed
1115137
Cluster license requires a base license to be installed
1115144
Cloud licenses cannot be deleted
1115178
A tier license that is still in use cannot be deleted
1115213
License is still in use and cannot be removed
1115406
Capacity pool licenses cannot be deleted
1115564
Package is part of a NLFv2 license and cannot be removed individually
66846823
A FlexCache license that is still in use cannot be deleted
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
