Delete a license
Deletes a license from the system when you need to remove obsolete or unused licensing information.
HTTP method and endpoint
DELETE /cluster/licensing/licenses/{name}
Introduced in
ONTAP 9.6
Related ONTAP commands
system license delete
name |
string |
path |
True |
Name of the license package to delete. |
serial_number |
string |
query |
True |
Serial number of the license to delete. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
525028 |
Error during volume limit check, cannot remove license |
525029 |
Current volume use will exceed limits if license is removed |
1115137 |
Cluster license requires a base license to be installed |
1115144 |
Cloud licenses cannot be deleted |
1115178 |
A tier license that is still in use cannot be deleted |
1115213 |
License is still in use and cannot be removed |
1115406 |
Capacity pool licenses cannot be deleted |
1115564 |
Package is part of a NLFv2 license and cannot be removed individually |
66846823 |
A FlexCache license that is still in use cannot be deleted |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
