Delete a UNIX user configuration for an SVM
Removes a UNIX user configuration for a specific SVM. Use this endpoint when you need to manage and update UNIX user access within your storage environment.
HTTP method and endpoint
DELETE /name-services/unix-users/{svm.uuid}/{name}
Introduced in
ONTAP 9.9
Usage notes
Deletes a UNIX user configuration for the specified SVM.
Related ONTAP commands
vserver services name-service unix-user delete
name |
string |
path |
True |
UNIX user name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
